Helping with an older vehicle to start…
2 replies to this topic
#1 _vbvbvb088_
_vbvbvb088_
Posted 31 October 2014 - 08:33 AM
Hi there
I have an old Ford (1966 six cyl) that has not been started in years. Before I have a go does anyone have a ‘doc’ / utube etc (with pictures) that details the most common issues?
Ie – start with most common failure point… up to the most difficult?
Under bonnet is as old as the hill’s. No mods. Just factory wiring that is pretty tired.
matt
#2 TerrA LX
Posted 31 October 2014 - 09:46 AM
Firstly, congrats on post 253.
Secondly, issues will be fluids and electrics.
A, clean carby out (inside float bowl), check needle and seat are not stuck and ensure fuel lines and tank are flushed and clean.
B, check condition of ignition system, clean/renew plugs points, check leads/cap/coil.
C, Change all fluids, oil etc.
D, flush cooling system.
Failure to do any of the above may result in blockages in one of the outlined systems.
#3 _LJ Kermit_
_LJ Kermit_
Posted 31 October 2014 - 04:01 PM
hello...
personal preferences. here..
change oil and filter.
first of all make sure the motor will turn freely by hand.
would suggest removing spark plugs and adding a little oil to the cylinders to maintain compression and minimise starting damage.
when electrics are ok ... leave the plugs out and turn it over on the starter motor to get oil pumping around the block, (at least 30 seconds)
when all turns freely and there is fuel in the carburettor...
assuming the timing is acceptable, replace the plugs and try to start it.
if it starts, listen carefully for any sounds of really dodgy running and shut it down immediately if so.
let it run for a few mnutes and make sure the coolant is being pumped through the radiator as the thermostat may be seized.
check the generator / alternator output at the battery terminals, should be around 13.5VDC
be wary of exhaust damage as exhaust fumes may not be vented properly.
best of luck with it....  hopes it runs well...
