Fitting a factory front bar
4 replies to this topic
#1 _Muzzy_
_Muzzy_
Posted 21 November 2014 - 08:52 PM
Hi all
I'm going to fit a std front factory sway bar, ( the bar has come from a UC and is going to be fitted to a LH the lower controls arms are pre drilled the K frame isn't
Are there any tricks with setting up the bar and drilling the K frame?
#2 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 22 November 2014 - 07:56 PM
Thought this would have been covered ...but holes will need to be drilled in frame (9/16 i think) so that the rubber "sinks" into the
hole and is retained by a plate on upper side of frame.
dimensions would help of where holes need to be drilled.
#3 _Muzzy_
_Muzzy_
Posted 23 November 2014 - 07:47 AM
cleared up one point that holes needed to 9/16 to allow rubber to be inserted
#4 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 23 November 2014 - 07:29 PM
I have done this a couple of times. Dummy fit the sway bar and line up the clamps on the k frame. Make sure there is enough metal for both holes. If I can do it anyone can!
#5 _Muzzy_
_Muzzy_
Posted 02 December 2014 - 05:39 PM
All fitted, easy job, I did need to pack the mount 3mm from the K frame to allow clearance for the twin pipes
