What have you changed since the last "tune up"?
Best to pull the cover off the the carbs and pull the tubes out and see what numbers are actually on each part?
3 wing nuts to undo and a good fitting screw driver/s and you will have them out in under 5 minutes.
Just because ol mate wrote down some numbers it pays to confirm,and even then, people that have numbered drill sets can bore things out while leaving the original number on the jet/s/bleeds etc.
sort of sounds lean, but if it was that bad you might expect a backfire, if it was that bad?
bloody hard to describe rich/lean conditions in words!
sounds like the mains are not pulling over early enough,hence the slight rant on emulsion tubes,they have different size "barrels" and the number/postion/size of holes all play a part in when this happens,being 2 chokes per cylinder kills air speed at sudden WOT openings.
Not enough signal at low engine rpm needs the mains to pull over early.
I would suggest fit some F2 and leave the rest and try that.
Edited by EunUCh, 18 December 2014 - 06:23 PM.
