Brake Advice
28 replies to this topic
#1 Potta
Posted 17 December 2014 - 10:40 AM
Just after some advice and guidance.
I got my 4 door going nicely again and took it for a little spin to make sure everything is working ok in the hope that I may be able to take it on a cruise or two before I sell it.
Anyway, all was going well, brakes working fine except the pedal felt a bit hard and there was the occasional squeak if I braked hardish, but I figured that's fine, it hasn't been driven for probably 18 months so a bit of crap on the disks is to be expected.
At one point I applied the brakes fairly firmly and after that the car started to pull to the right a bit. After a short while it became obvious that the right front brake was partially stuck on, I could smell that hot brake smell, it was pullling to the right and when I applied the brakes it would point straight again.
So I decided to limp it home slowly.
After a while, the brake seemed to unstick itself, and the brakes were back to normal the next time I stopped.
However, the next time I went to stop, the pedal went straight to the floor, twice, third pump they worked ok but not properly.
So I kept going, super careful and pumping the brakes at every intersection and managed to get it home.
I checked the fluid immediately and it was full to the top but looked sort of milky, but still green.
I can't see any leaks anywhere and when I put the car away the brakes felt normal.
Could this just be due to old/contaminated fluid getting hot from the sticky piston and then becoming compressible or does it sound like a more serious issue?
Before it goes out again it is getting a full flush, but should I check anything else as well?
#2 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 17 December 2014 - 10:58 AM
Datto is your best man to consult with but I'll give you my opinion.
the braking system in an old car doesn't like not getting used.  So if you car has been sitting for 18 months, like you said, things deteriorate.
Sounds like your brake booster needs overhauling.  I'd also overhaul/check the brake master cylinder and flush out the brake system and add new brake fluid.
Doesn't cost that much to do and it gives you peace of mind, and it's a good selling point.
#3 S pack
  • 15,539 posts
Posted 17 December 2014 - 11:12 AM
If the brakes were working ok and suddenly the pedal went to the floor and had to be pumped up and there are no obvious fluid leaks then the only conclusion can be a master cylinder fault.
#4 Potta
Posted 17 December 2014 - 12:09 PM
Yeah I was hoping you wouldn't say that Dave.
On a positive note, it drove great and no pool of tranny fluid today, so progress has been made!!
#5 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 17 December 2014 - 12:18 PM
Sorry I replied, was only trying to help.  Won't do it again.
#6 Potta
Posted 17 December 2014 - 12:42 PM
Geezus Mick, I didn't mean to diss you mate.
Thank you also for your input, it is appreciated.
I'm a bit of a social retard so please don't take it personal.
I read Dave's post last that's all.
#7 TerrA LX
Posted 17 December 2014 - 01:15 PM
Pedal to the floor in a correctly bled system sounds like M/C failure to me also.
#8 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 17 December 2014 - 02:52 PM
I think it might be a seized caliper that caused all the problems . The caliper seized causing the brake fluid to boil in that caliper , it then unseized which caused the low pedal . The milky colour in the fluid could be a sign of boiled fluid as well ?
#9 TOERUNNER
TOERUNNER
  • 620 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
i would also check the brake hoses , as they can hold the brakes on also
#10 TerrA LX
Posted 17 December 2014 - 03:10 PM
Smells like water contamination to me.
#11 _LS1 Taxi_
_LS1 Taxi_
Posted 17 December 2014 - 03:24 PM
Seized RHF caliper for sure.
#12 S pack
  • 15,539 posts
Posted 17 December 2014 - 03:33 PM
Quote: "After a while, the brake seemed to unstick itself, and the brakes were back to normal the next time I stopped.
However, the next time I went to stop, the pedal went straight to the floor, twice, third pump they worked ok but not properly".
I agree the sticking right front caliper could have caused the brake fluid to boil, so why did the brake pedal go to the floor on the second brake application after the caliper came good and not whilst the caliper was stuck/seized???
#13 _LS1 Taxi_
_LS1 Taxi_
Posted 17 December 2014 - 04:21 PM
Caliper seized on due to piston/bore corrosion which caused the pads to drag and car to pull right.
Eventually freed itself however brake fluid boiled and front flexible brake hose softened/swelled.
Goes to stop again, piston bore corrosion has caused the piston to retract past the stuck spot and a combination of this plus the boiled brake fluid / soft brake hose requires 2 or 3 jabs to get a pedal.
I'd be pulling off the RHF caliper and putting a kit through it ASAP (I'd do the LHF at the same time).  While down there, check the flexible hoses for signs of stretching / wear.
Replace as necessary, completely bleed brake system to change out all fluid.
Road test.
#14 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 17 December 2014 - 04:47 PM
Think of it like taking the cap off a radiator , more room less pressure . Heat rises , so the aerated fuild would work its way up through the system .
#15 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 17 December 2014 - 05:07 PM
As already mentioned,caliper overhaul assembled with a good quality rubber grease around piston/behind dust cover.
Brake fluid is corrosive and even though you may not see a leak a very small amount gets past the seal,it is a lubricant as well.
Same deal goes for the master cylinder when it sits,the very small amount of fluid that does get out reacts and causes corrosion hence
a bad seal,have pulled some apart and even though sealed you get a "mark" where the buckets/seals sit for long periods,they need to used.
#16 Potta
Posted 17 December 2014 - 05:33 PM
Ok, cheers guys, I'll let you know when I start pulling stuff apart, might be a while due to $$ being involved lol.
#17 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 December 2014 - 06:19 PM
Hope not to offend.
Just sell it Craig as a work in progress. Then put all cash towards the green beast. You'll also save a heap in rego and insurance.
Brakes could get expensive and I doubt you'll get that money back.
Marty
#18 Potta
Posted 18 December 2014 - 12:51 AM
Yeah, fair call mate
#19 rodomo
  • 17,999 posts
Posted 18 December 2014 - 09:19 PM
Sell it to Dave?
#20 Potta
Posted 18 December 2014 - 11:36 PM
I'll sell it to whoever will give me an appropriate amount of cash  :D
#21 Potta
Posted 10 March 2018 - 10:45 PM
Fck me 3 1/2 years since the brakes fcked up in this thing?
Where is the time going???
Anyway, still can't get pressure in the pedal, no fluid coming through when trying to bleed, fluid is definitely coming out of the master cylinder, got splashback in the face lol.
Any ideas what could be the problem?
I can't see any leaks, no movement in the new slave cylinders, flexible line isn't moving and has no kinks.
I'm thinking maybe a blockage but then you'd get pressure right?
Is it worth blasting some air through there?
Any tips for doing that safely/without fcking stuff up?
Any ideas as to what else it could be.
I just want to get it fixed so I can move it on.
Thanks in advance.
#22 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 10 March 2018 - 11:42 PM
Have you tried disconnecting the rubber line & then "gently" pushing the pedal & the fluid drpping into a ice cream bucket or something, that will show if you have fluid going to there first ? If so work to the next bit & so on. Those flexible hoses can stuff up with age. & you're probably going to need some brake clean, heaps of rags & your compressed air & most importantly eye protection. There's like 5 or 7 lines all up & 3 hoses, not much to check.
#23 Potta
Posted 11 March 2018 - 01:03 AM
Thanks Gary.
You're right, I'll have to take the time to go through the whole system and sort it out.
Going to try bleeding the master cylinder first, have seen a couple of guys on youtube do that when they have changed their master cylinder, and the symptoms of not doing it seem to match what I'm seeing.
Ie no brake pressure, bubbles in the reservoir.
#24 Rockoz
Rockoz
  • 3,967 posts
  • Name:Rob
Posted 11 March 2018 - 08:55 AM
Years ago I bought a vacuum oil changer when I had a sterndrive boat.
Great invention I was told.
Put a tube down the dipstick hole and suck the oil out and away you go.
Followed the instructions.
Only took 3 hours to get the oil out.
Time I could have used to clean the boat floor from spilled oil if I took the sump plug out, and a shit load of beers at the club.
Found the vacuum unit useful for something years later.
Its great for bleeding brakes.
Put the tube on, pump the vacuum, undo the bleeder and away you go.
Just need to keep an eye on the reservoir.
Was about 30 bucks. Great for bleeding brakes anyway.
#25 dattoman
  • 16,471 posts
Posted 11 March 2018 - 08:55 PM
Got a hoist yet ?
