Ok so been a while on the green machine and the motor now has about 3000 mile.
the owner now has a few more kay's on his torana holden 6 brain now which is a good thing.
The new cam is a cracker in the car, but there is some pinging and I have been reading some literature on the subject and wanted to start to get to the bottom of the tune on the car.
went harry's at liverpool last night and on the way home at " sea level " 11pm the car was pinging 80 klms wot from there - which is not a good tune
there is a few things that I need to state up front and they are;
1) i have used nulon fuel additive octaine booster in the car
2) it's not been on the dyno since the cam change
3) after being defected i re routed the breather pipe into the carby N#3 and not the manifold as per previous
4) there 1 3/4 CD strombergs on a lynx manifold - will post photos later
5) 1 and 2 - were lean - brown and seemed the right colour - but this could have been the octaine boost - nulon
6) 3 and 4 were the right colour - ditto as per no 5 above
7) 5 and 6 were oily looking and crusty with dags - which didn't look good
So today I started trying to understand the pinging issue and why at sea level it was inclined to ping @ 11pm at botany
SO i started to work my way right from the start I;
1) I pulled all plugs out and cleaned then fully - the plug is a BP6F S - I have to check this plug range
2) pulled off the rocker cover and checked TDC and confirmed that the mark on the powerbond balancer was in the right spot - Yep
2) Did a quick check of the tappet clearances and found that there was some excessive gaps post last cam install - I re adjusted all the gaps
3) i took out the rocket breather pipe which I had been put into No #3 carby and then " blocked off the rocket cover as per original " - should have know better on this one - but kept the front " old style breather",
4) I re balanced all the carbies on idol with the arms off and with an air flow meter.
5) adjusted all the arms on the linkage to be operating all the throttle butterflies at the same time
6) it's a low comp head with 67 CC chambers - but extensive port work - I didn't do it - I also don't know the valve size
7) the cams got >488 lift @ 1.5 rockers - will see 6.5K plus no problems at all
The outcome of the tune up was;
- Post tune up plug colour - My bloody apple phone is now full and it cannot take photos - so can post tomorrow - BUT 1 & 2 & 5 & 6 - need a bit more fuel - 2 and 3 perfect colour
- I took if for a big flog and it blew the dip stick out and oil went everywhere after a few big - 6.5K plus revs off standing starts - this was the result of blocking off the breather from the carby
- Still has a hesitation off idol and early throttle - but think that its running lean - as per the plugs colour - which i cannot post ATM
- NO pinging at either Big REV ( standing start drop clutch 1-2-3 gear ) t OR 80MPH WOT
After the plug read i gave carby 1 and 3 a 1/4 turn on the main jet.
SO WTF happened today that didn't happen last night ?.
1) I didn't touch the timing
2) I think the car is running lean - which i can fix
3) I adjusted the valve timing
Question that i need some help on is';
1) if it's running lean will this cause pinging - it may because the chamber is hotter
2) does excessive tappet clearance cause pinging - solid
3) if i fatten up the fuel / air this should assist
4) what plugs are others running " heat range"
F#$#$#K i sound like MIKE 73 - PS where is Mike 73 - got his answers I suppose
any training wheels would be appreciated
