Take one engineless 1982 Starlet and a Toyota Altezza 4 cylinder Beams engine and a 6-speed gearbox and you have a Starezza.
I bought as it has a current homologated roll cage, set of slicks and some other stuff and then bought an imported JDM Beams engine which pokes out 207HP standard.
As I got further and further into the project i started to think that this car needed a few additional things put right.
I still have a fair way to go and little money to spend but I feel since I started the remake on December the 14th I have made headway and still on target of a 3 month makeover doing it after work and when and if I get enough time on the weekends.
Found panel steel in the back shed
Bit of cutting and welding
Some new engine mounts
Using the Altezz gearbox x-member and making mounts to suit
Took ages of mucking around to fit the seat including raising the steering wheel 40mm and now I can get into the seat without taking the wheel off as when they built the dash they made it too low! I will fix this later. I actually removed all the frame from underneath that previous people had done and and the bodgey bolts on various angles.
Once all this is done then the engine need wired.... this is a mission on its own as the engine is fairly high tech and with Dual VVT-i and electronic Throttle Body I may have some fun. The Diff needs replacing and the suspension needs raising. The driveshaft needs shortening, radiator fitted, exhaust made, An heap more
Angled the handbrake beside the gear lever
The tunnel was weakened so I spen a bit of attention adding strength back into this area
