Red 202 lower thermostat housing without heater lines
coolingLH 202 Thermostat heater
38 replies to this topic
#1 _jeppo_
_jeppo_
Posted 06 January 2015 - 08:26 AM
I've recently installed a set of triple Webers onto my LH SLR3300 Torana but had to remove the original heater box to get them to fit. As I no longer have a heater I have no need for the heater lines running from the lower thermostat housing. As a temporary work-around I have just put a loop of heater line between the 2 outlets on the housing. Does anyone know if there is a suitable lower thermostat housing without heater outlets out there to purchase? or any other suggestions?
Thanks.
#2 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 06 January 2015 - 10:57 AM
hi i bought a new one with heater out lets $120 not cheep. i then took to my engine man and he welded up the holes and then i put the cups on them that way no chance it would leek. but you could cut down the tube bits and get welded up might be a way of doing it
#3 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 06 January 2015 - 12:26 PM
There is this type but Im pretty sure they only fit the early 149 heads.
#4 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 06 January 2015 - 12:48 PM
There are rubber blanking caps available from autobarn, repco etc.i have used these on my LS in the L J.
Or you can insert an appropriate sized standard bolt or hex drive bolt (neater looking) into the outlet with some sealant. This was how it was done on an engine I bought. It never leaked.
Either method should cost you well less than $10.
#5 _duggan208_
_duggan208_
Posted 07 January 2015 - 12:13 AM
That bolt pattern is wrong for a red motor. Is that of a gray motor. You could try tapping them and fitting brass plugs.
Regards
#6 S pack
  • 15,538 posts
Posted 07 January 2015 - 12:41 AM
I'm sure the early red 149/179 housing will bolt up to the later red heads. Just have to plug two unused holes in the end of the head.
Edited by S pack, 07 January 2015 - 12:41 AM.
#7 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 January 2015 - 07:28 AM
Duggan, early 149 red heads used these housings.
Correct, Dave. Gotta plug 2 holes to use them on later heads.
#8 _jeppo_
_jeppo_
Posted 07 January 2015 - 07:36 AM
Thanks guys.
Think I'll go down and get the rubber blanking plates and give them a try.
I've got a spare lower thermostat housing so I might try and weld it up and see how it looks. (I'll post some pics if i get it done).
Thanks again.
#9 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 January 2015 - 07:43 AM
A pic for those wondering.
#10 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 07 January 2015 - 03:36 PM
hi again dont think you can weld the old ones they are cast the new ones are alloy and can be welded. i welded mine to make sure that the rubber things did not come of just to make sure
#11 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 January 2015 - 03:44 PM
You can weld them up with cast iron rods using a stick welder
Just be sure that the surface is prepped well.
Edited by wot179, 07 January 2015 - 03:44 PM.
#12 basicgreen
basicgreen
  • 225 posts
  • Name:rick
Posted 07 January 2015 - 03:47 PM
i stand corrected
#13 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 07 January 2015 - 05:34 PM
Hi Duncan,
Take a look at this thread and look at the third image down that was posted on the 18th of March.
http://www.gmh-toran...1-heater-hoses/
If this is the look you are after then try this
Buy:
1 7/16 UNC tap
1 9.4 mm drill
2 1 inch 7/16 bolts
1 10ml bottle of Loctite 263
2 5/8 rubber blanking plugs
2 Hose Clamps to suit - if you want you can use the blanking plugs and clamps from Rare's
Drill tap and loctite the 2 bolts in - fit blanking plugs - will never leak and looks pretty good, (its what I did for my LC)
Cheers Brian
#14 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 07 January 2015 - 05:59 PM
As already mentioned,drill,tap,grub screws,thin smear of sealant on threads (cheap arse 5 min araldite),cap if you want.
#15 S pack
  • 15,538 posts
Posted 07 January 2015 - 06:57 PM
Alternatively you can bronze up the holes with an oxy.
Edited by S pack, 07 January 2015 - 06:58 PM.
#16 kiwi-lilj
kiwi-lilj
  • 1,420 posts
  • Name:Blair
  • Car:LIL J
Posted 07 January 2015 - 07:19 PM
Alternatively you can chip all the flux off of the cast arc rod and then use it with a Tig.
#17 _duggan208_
_duggan208_
Posted 07 January 2015 - 11:23 PM
Well there you go, learn something new every day. The early 149 pic bolted on the head brings every thing into perspective.
Regards.
#18 Dr Terry
Dr Terry
  • 3,276 posts
Posted 08 January 2015 - 03:40 PM
The 2-bolt lower housing was fitted to ALL 149 & 179 engines, not just early ones. The 2 hoses weren't required because the inlet manifold was not water heated, it was heated by the exhaust.
As you can see in the pics, the housing is held by only 2 bolts. The lower right threaded hole is present in the 149/179 heads, but not used.
The water hole that you can see on the lower left is not present on 149/179 heads. If you fit one of these old heads to 161/186 & later motors, it needs to be drilled.
If you want to use the 2-bolt housing on a later head, just tap out the water hole & fit a hex grub screw (with sealant) & that's it, no welding required.
Dr Terry
#19 _deantl2003_
_deantl2003_
Posted 08 January 2015 - 10:29 PM
here is photo of mine, which is very similar to yours..
  • Attached File  010.JPG   48.04K   9 downloads
#20 _cabby_
_cabby_
Posted 05 August 2018 - 10:47 AM
Hi All,
I know this thread is old so sorry for reigniting.
I have just bought the Rare Spares lower thermostat housing https://www.rarespar...lower-base-6cyl and put it on my LC with 186.
It doesn't run a heater. I have blanked off the two outlets on the right hand side of the housing looking from the front with rubber plugs and clamps but I am having trouble with the threaded outlet on the left hand side, I put a bolt in that I thought fit and put thread sealant on the thread but when I started it up again she leaked out of the threat reasonably badly.
Can anyone tell me the correct bolt/thread side for the left hand side so I can blank it off or if someone sells an aftermarket blanking bolt.
Thanks in advance.
Chris
#21 S pack
  • 15,538 posts
Posted 05 August 2018 - 11:31 AM
Chris,
AFAIK, the original thread size in the thermostat housing should be 1/2" BSP.
You should be in need of a 1/2" BSPT hex head brass plug which you will find at any Plumbing Supplies or dare I say it, Bunnings, in their plumbing section.
#22 _cabby_
_cabby_
Posted 05 August 2018 - 04:38 PM
Thanks S Pack,
I have just picked up a 1/2 BSP plug from Repco, I will give it a go.
Chris
#23 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 05 August 2018 - 06:32 PM
You'd call it a grub screw in automotive terms & if you have done the 1 on the drivers side, tap the housing & fit 2 on the passenger side rather than worrying about the rubber plugs failing & they definitely do ! Gary.
#24 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 07 August 2018 - 04:33 AM
Am i right to say if you use an U piece of hose not
restricting flow for the manifold outlet inlet on
thermostat housing helps in the event of the thermostat
failure... the water can still circulate..
#25 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 07 August 2018 - 06:34 AM
Maz, both are below the thermostat so no.
Also tagged with one or more of these keywords: coolingLH, 202, Thermostat, heater
