400 chev in lx torana engineering
Posted 18 January 2015 - 10:02 AM
im currently getting my 400 chev built up by Tony at speedworks (im in vic) and was just wondering engineering wise who would be the best person to go to look over the car etc once its all done?
I know that bigger brakes, new seat belts emissions canister would be required. If i was to get the chassis strengthening kit from crs would that help too? And have i missed anything else that should be done so i can please them in one go and not waste their time going backwards n forwards.
Cheers everyone!
Sammy
Posted 18 January 2015 - 01:04 PM
Find an engineer first before you spend any more money
Your rego authorities might not allow the 400
#3 _434LX_
Posted 18 January 2015 - 02:29 PM
Posted 18 January 2015 - 03:42 PM
Posted 18 January 2015 - 03:44 PM
If you stroke a 350 its a 383
Still over the limit
So do you care about it being legal and insurable or not ?
Posted 18 January 2015 - 03:49 PM
Posted 18 January 2015 - 04:10 PM
I haven't read up on this for a while but from memory there are no engine size restrictions if you call it an ICV (Individually Constructed Vehicle).
BUT (the really big BUT is that) if you call it an ICV you become the "manufacturer" and it has to comply with all the current ADRs the same as if it was a brand new car that left the factory on the day you get it engineered and by the sound of it, the vehicle emmissions alone will be hard to get around.
See Third Edition ADRs here: https://www.infrastr...adr_online.aspx
As Datto said, you need to consult with an engineer before you spend any more money.
I hate to say it but if you're committed to this engine build you may have to consider swapping the Torana for something with a greater (highest factory option) tare weight, for example, a VH Commodore SL/E had a tare of 1370kg which works out to 418 ci?
And I'm not even going near the subject of insurance...
Posted 18 January 2015 - 04:30 PM
Posted 18 January 2015 - 04:36 PM
Just on a side-note:
an 1183kg Torana has a maximum engine size of 5915cc under NCOP
an LS1 engine is 5670cc
an LS2/L76/L98 engine is 5965cc
That means an LS2 is just 50cc over the limit but I've seen quite a few 6.0L engines in Toranas, is there some "tollerance" as this is within +/- 1% or are people just fudging the numbers slightly?
A difference of 6.25cc per cylinder is litterally a droplet, I'd reckon dome-top pistons or a good block decking would account for more than that?
#10 _NewsuxLX_
Posted 18 January 2015 - 05:33 PM
#11 _NewsuxLX_
Posted 18 January 2015 - 05:52 PM
Posted 18 January 2015 - 07:16 PM
#13 _Bomber Watson_
Posted 18 January 2015 - 07:21 PM
At a rough guess i would say 60% of people on this forum are driving illegally modefied cars, whether they know it or not.
Personally i wont hold a grudge against you if you go the bigger engine. When i had a LH and a 400SBC sitting in the shed at the same time i had every intention of just saying it was a 350....Ended up turboing the 202 that was in the car though then selling both haha.
Posted 18 January 2015 - 07:41 PM
#15 _Bomber Watson_
Posted 18 January 2015 - 07:46 PM
Im not fluent with chevs, so this might be a bit off.
Pretty sure the pistons definitely wont go, 350 is 3.990" from memory and im pretty sure 400 is 4.125" or somethign like that.
Rods im not so sure, they might work.
Posted 18 January 2015 - 07:55 PM
#17 _Bomber Watson_
Posted 18 January 2015 - 07:58 PM
Persionally i would be inclined to buy a cheep gm 350ci crate motor, do the 400 up on the side, do the swap then you have a low km gm crate motor for sale to the hot rod guys.
Posted 18 January 2015 - 08:06 PM
#19 _Bomber Watson_
Posted 18 January 2015 - 08:14 PM
#22
Posted 18 January 2015 - 08:20 PM
Ah wel there ya go! Learn something new everyday! Cheers mate!
#23
Posted 18 January 2015 - 09:48 PM
You are Ok to go up to 6.3 litre, its based on the heaviest Torana which is the A9X at over 1250 kgs.
#24
Posted 19 January 2015 - 01:38 AM
LH L34 Sedan:
Kerb Weight: 1306 kg
LX A9X Sedan:
Kerb Weight: 1306kg
LX A9X Hatchback:
Kerb Weight: 1242kg
So it seems under NCOP we have a maximum allowable engine capacity for a Torana Sedan of 6530cc (398.485ci)
And for Hatch a maximum capacity of 6210cc (378.957ci)
You're getting closer Sammy, I figure a 400ci Chev is a bee's dick under 6555cc so now you're only 25cc away (assuming a sedan), that's less than half a percent over the limit.
It may be worth confirming whether the 400ci figure is exact or a marketing term and then going back to your engineer with the correct values?
#25
Posted 19 January 2015 - 08:30 AM
LH L34 Sedan:
LX A9X Sedan:
Kerb Weight: 1306kg
LX A9X Hatchback:
Kerb Weight: 1242kg
Yeah ive got a sedan so just under!! I'll let him know about the weight figures you found and if he asks i can always print off the page and show him. Maybe maybe it could be a 383 chev on paper so it's under the cc limit. I'll see what he says n even ring a few n let you know the answer
