No ignition light's on LX Dash
No ignition lights No ignition lights LX Dash LX Dash no Ignition Lights
16 replies to this topic
#1 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 30 January 2015 - 07:00 PM
Hey guys and gals, Just got my LX home. I'm attempting to put my wiring harness back in and I'm having trouble with the LX Ignition lights. The ignition lights are not lighting up and I'm stumped :banghead: . I have tried powering up the RED and PURPLE wires to the ignition switch, with a fusible link, which is direct from my battery as i have no motor in at the moment. I am getting power to the ignition switch, but still no lights on the LX dash.What I know about electrickery you could fit in the end of a condom.
Any tips and help would be greatly appreciated :) Cheers! :nopity:
#2 _hutch_
_hutch_
Posted 30 January 2015 - 07:26 PM
With out the motor in you won't get any lights coz the electricity has no where to go
#3 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 30 January 2015 - 07:27 PM
Cheers, il check it out!
#4 Statler
  • 6,282 posts
Posted 30 January 2015 - 07:56 PM
Did you turn the headlamp switch knob?
#5 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 30 January 2015 - 08:47 PM
Yes, i have turned the headlamp switch knob and have light illumination, but still no red dash lights.
Edited by Oysterhead, 30 January 2015 - 08:58 PM.
#6 hanra
  • 10,832 posts
Posted 30 January 2015 - 09:05 PM
As hutch has already mentioned. You have no path for current to flow. Once you have the engine installed and all sensors hooked up. Then come back here and let us know how you go.
#7 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 30 January 2015 - 09:16 PM
Copy that Brad, was just trying to get a jump on my assembly, Thanks.
#8 IMORAL
IMORAL
    Bored
  • 2,567 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 30 January 2015 - 10:58 PM
Clamp your battery cable and ignition cable together with vice grips. (Just the wires that go on the big post on the starter motor) one of the small ones will be to activate the starter.
Worked for me when my engine was out and I wanted to check some electrical things.
#9 _76lxJAS_
_76lxJAS_
Posted 30 January 2015 - 11:01 PM
a bit more info the you can put in the top of that condom,
each red light has to earth from the sender units in the engine, without the engine as said above you will have no circuit for the power to run.
is your cluster a ss/slr ? or one with a clock?
is your fuel gauge working?
to test the circuits try connect up the sensors and earth them to the body somewhere.
#10 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 30 January 2015 - 11:27 PM
Thanks Paul & Jason, will give it a go. My cluster has the one with the clock SL. Thanks again!
-Marcus
#11 Dr Terry
Dr Terry
  • 3,276 posts
Posted 31 January 2015 - 08:28 AM
Very simple.
To test the 3 dash indicator lights, just temporarily connect the green (temp switch), dark blue (oil switch) & brown (alternator) wires to earth & switch on the ignition. All 3 should light up.
These 3 wires are in the engine harness & are the ones which connect directly to the switches on the engine.
Dr Terry
#12 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 01 February 2015 - 07:27 PM
Thanks Dr Terry, will try it out!
#13 ben23
ben23
  • 236 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 02 February 2015 - 06:23 PM
Just note anyone with a SS/SLR dash DONT directly earth fuel, temp or oil wires or you will fry the gauges. With S/SL is fine, only warning lights, except fuel of course.
#14 Dr Terry
Dr Terry
  • 3,276 posts
Posted 03 February 2015 - 07:05 AM
Yes, very good point, but the OP had already said it was an SL clock dash.
Dr Terry
#15 ben23
ben23
  • 236 posts
  • Name:Ben
Posted 13 February 2015 - 05:22 PM
I know this, just thought I'd put it in everyones head, wouldnt want anyone seeing this who might not understand that you cant test gauges the same way and then blow up their cluster, thats all!
#16 S pack
  • 15,539 posts
Posted 13 February 2015 - 05:41 PM
You can test thermal type gauges by earthing them out, just be ready to disconnect the earth or the power supply the moment the gauge needle reaches its maximum reading.
Best though to incorporate a 10 ohm resistor into the earth wire to protect the gauge.
#17 ben23
ben23
  • 236 posts
  • Name:Ben
Posted 13 February 2015 - 06:19 PM
yeah not good practice though, in a pinch a normal 2 watt test light works. Otherwise a gauge tester is best
