www.streetguardian.info
I have 2 of his early camera's. One I took back after 18 months and he is replacing a bulged battery. I don't expect he will charge me. This bloke is in Sydney and when he get's them made, they are made to his specs.
In regards to dobbing, I don't see it that way. I reported a government bus driver for going through a red light. It was red before he approached, and he still went through it. I said to the girl on the line that if he isn't taken to task, I would put the video on youtube, as the footage clearly showed the red light, the bus and registration number.
A few things. You turn off the speed recording on the cam, have the date and time turned on, GPS turned on and reading if it is equipped, voice recording turned on, and if you want to hard wire the cam, there is a Gforce knock sensor that will start recording for 5 minutes or so if the car is knocked while you are away, capturing the dope who hit your car. Also, if you brake very heavy, emergency braking, footage from 30 odd seconds prior to you braking to some minutes after is automatically saved, for future use. In regards to turning your speed off, if push comes to shove, the police can work out your speed from the footage, so if there is a question of speed involved, they can work it out.
Whenever you get pulled up for breath testing etc, you must tell them you are recording their voice on dash cam. If you don't, the recording can't be used if something goes to court.
The dash cam guy I only know through a forum I'm on, but he knows his stuff, unlike the shops that retail this stuff. Picture quality, night and day is very important. Hope that helps.
