LJ GTR Air Cleaner Questions
#1 _macdou_
Posted 26 February 2015 - 06:00 PM
Chromed not chromed
Sticker / Decal ?
Thanks...
Posted 26 February 2015 - 07:48 PM
Hi Ken, you might need a month too.
I've seen a very late 73 with some extra hose in the air cleaner. This car had a few non-conforms for a 73 but I was assured that bit was correct.
Otherwise I'd say chrome, no holes, no sticker
Marty
IMG_7054.jpeg 37.96K 35 downloads
#3 _macdou_
Posted 26 February 2015 - 08:02 PM
I didn't realise 1972 was that different to the 1973 GTR's....
Marty's Picture....
Edited by macdou, 26 February 2015 - 08:04 PM.
Posted 26 February 2015 - 08:32 PM
This air cleaner is not correct for an ADR 27 compliant GTR.
ADR 27 air cleaner assy was the same for all 2250, 2850 and 3300eng Torana, std black snorkel type.
#5 _macdou_
Posted 26 February 2015 - 08:47 PM
Posted 26 February 2015 - 08:58 PM
January 1972 up to 30/09/1973.
#7 _macdou_
Posted 26 February 2015 - 09:02 PM
So then they went to the black long snouted air cleaner for the GTR? Not sure what they were thinking if that was the case..
Posted 26 February 2015 - 09:11 PM
After 30./9/73 I guess the air cleaner had that extra hose. That one pictured is a 11/73
Marty
Posted 26 February 2015 - 09:32 PM
GMH commenced compliance with ADR 27 on 1/10/1973. So HQ & Torana manufactured on and from the 1st October 1973 were to be compliant with ADR 27 even though ADR 27 didn't come into force until 1/01/1974. XU1 was the exception and did not change.
At the end of the day LJ production was finishing in about 4 months so why spend money modifying the GTR chrome air cleaner for the limited number of GTR's that would be produced. Also I suspect the wide open spaces of the GTR air cleaner may not have been conducive to proper operation of the Positive Closed Crankcase Ventilation System.
I
Posted 26 February 2015 - 09:53 PM
Hi Ken, pretty sure my rocker cover is available on the early 73.
Marty
Hey Marty
Actually the 1973 type rocker cover commenced in production in November 1972.
Dave.
#11 _macdou_
Posted 26 February 2015 - 10:10 PM
While your running hot Dave, what's the Carby and manifold?
Single barrel Stromberg, do you know which type or what is the throat diameter of the carb?
Posted 26 February 2015 - 10:25 PM
Hi Ken
Single barrel stromberg BXV-2.
Venturi dia. 1.219" (3300 excl XU1)
Throttle bore dia. 1.44" (2850, 3300 excl XU1)
Posted 26 February 2015 - 10:39 PM
Hi,from BLJ31000A,BLJ53000A Public photo 10 month 73 adelaide.
Posted 27 February 2015 - 07:37 PM
Hi Dave,
My 12/73 GTR has a Stomberg BXUV-3 carb with the 1 9/16" throttle bore
Isn't this correct for an ADR 27 car?
It also has the plain black snorkel air cleaner, and the 3 hole rocker cover (chrome)
Cheers Kev
#15 _macdou_
Posted 27 February 2015 - 08:43 PM
Is it like this one Kev, the rocker cover in the second pic that is....
Edited by macdou, 27 February 2015 - 08:48 PM.
Posted 27 February 2015 - 09:06 PM
Hi Dave,
Cheers Kev
Hi Kev
Apologies, I should have clarified the carby specs I posted are for pre ADR 27 202's.
The ADR 27 Stromberg carburetor is different however the only info I have is the part numbers. I don't have any technical specs for the revised carby.
Dave.
Posted 27 February 2015 - 09:16 PM
Hey Marty
Dave.
Sort of.
There are 3 different 6-cyl rockers for LJ (if you don't count the chrome variants).
The early ones have the PCV valve sitting in a type of 'extension tube' which is welded to the rocker cover, they'd been like this since EH.
The next type, introduced in late 1972 saw the PCV valve sitting in a lower pressing (small hump) in the rear of the cover.
From around 1/10/73 onwards the rocker cover had 3 holes; 1 for the oil cap (now sealed), one for the PCV valve & 1 for the newly added pipe to the air cleaner.
Dr Terry
#18 _macdou_
Posted 27 February 2015 - 09:20 PM
Sort of.
Dr Terry
Dr Terry did all three types have just the 2 wire holders like mine above? And was this unique to LJ's or did other models have the same two wire holders?
Posted 27 February 2015 - 09:31 PM
Sort of.
Dr Terry
Dr Terry
The PCV tube in the EH to 1972 LJ rocker cover wasn't welded to the rocker cover.
Posted 28 February 2015 - 07:02 AM
Dr Terry
My point was that it was a separate part that was attached in some way, crimped & then spot-welded perhaps.
Dr Terry
#21
Posted 28 February 2015 - 08:26 AM
Marty
The rocker cover my be correct for a late 73 gtr, but were these ones chromed or red.
However I noticed that there is a voltage regulator in the inner guard which had been deleted in 73 models, the engine bay appears to be painted grey as per Adelaide cars but it has a Preslite /Brisbane wiper motor.
The brake fluid decal is on the heater box which I have only seen like this on Adelaide built Lc torana's.
As far as I'm aware all Lc /Lj rocker covers only have the 2 rear wiring clips.
#22
Posted 28 February 2015 - 09:16 AM
GTR Pre ADR 27 two hole covers - chrome
GTR ADR 27 3 hole covers - chrome
All LC & LJ 6cyl rockers covers only have two wiring clips
#23 _macdou_
Posted 28 February 2015 - 12:31 PM
Maybe someone can add text to the pics to reflect correct model and ADR....
Posted 28 February 2015 - 02:47 PM
Rocker cover at top - suit LJ Torana - 3 hole ADR 27 compliant, introduced into production on and from 1/10/1973.
Rocker cover at middle - suit LJ Torana - 2 hole (Pre ADR 27), introduced into production during November 1972 through to 30/09/1973.
Rocker cover at bottom - suit LC & LJ Torana - 2 hole, used in production up to and into November 1972.
All 82911 model rocker covers CHROMED, S & SL rocker covers painted.
#25 _macdou_
Posted 28 February 2015 - 04:08 PM
Thanks Dave great stuff.....one more detail if you can let us know
For the three variants relating to 82911 GTR models only:
Chromed / Painted
Sticker or No Sticker
