hi all
thought i would start restoring where mike finished of after much debate with panel shop it was decided to get the c completely blasted back to metal and primed ( gbt blasters at wingfeild john top job ) i was a bit sceptical on what was under all that paint turn out to be not as bad as what i thought ? still running original boot with minor pitting, engine bay in good condition with repair work required under battery tray, rear quarter panel requiring panel work ,floor in good condition requiring little work , roof needs panel work , the rest as you know was repaired by mike so over all should be a good project , all panel work / spray painting will be done by panel shop . all panels where required will be lead wiped and filled ? as project goes i will post photos ?
cheers john
