409 Stainless welding
14 replies to this topic
#1 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 20 March 2015 - 04:55 PM
Hi,
I am thinking of buying a DIY extractor kit for my LS1 conversion.
It has 2 flange plates and 30 assorted bends to make a set of 4-1 extractors, it comes in 409 stainless and I thought as I only have a simple mig I should do it in mild steel but have been told I can use my mig as I would use it on mild steel to weld the 409 as it will bleed into the wire and be fine.
Any thoughts from you welding guys?
If it works I think it is an achievable task but I am a bit surprised to use a mild steel mig setup
Cheers, Tom
#2 Bigfella237
  • 4,371 posts
Posted 20 March 2015 - 08:02 PM
Every muffler shop I've ever been in uses the same MIG for mild and stainless exhausts, some paint the welds afterward to stop 'em rusting, some don't.
If it were me, I'd be saving my money and getting the mild steel kit, then spend what you saved on ceramic coating? The coating will look almost as good as stainless and will help keep engine bay temps down, plus the inside of the pipes get coated as well. In theory, ceramic coated mild steel should last just as long as stainless?
There again, if money is no object, buy the stainless kit and then get that coated!
#3 _Bomber Watson_
Posted 20 March 2015 - 08:14 PM
TMK the weld will rust.
#4 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
Posted 20 March 2015 - 08:52 PM
Thanks for the responses, very helpful
Will probably go for mild steel and get it coated
Cheers,
#5 dattoman
  • 16,470 posts
Posted 20 March 2015 - 09:02 PM
I concur
Got mild and save some money for coating
409 is a shit grade stainless thats about all that can be easily bent for the exhaust industry (cheaply and easily)
It will still turn brown fairly fast
So best just go with the mild and coating
#6 _76lxJAS_
_76lxJAS_
Posted 20 March 2015 - 11:02 PM
you can weld stainless fine with a mig with stainless wire. just use straight argon gas, not argoshield
as above though, 409 is not thes best quality stainless,
i done all mig with the mig but its 304 stainless.
#7 N/A-PWR
  • 9,595 posts
Posted 20 March 2015 - 11:31 PM
Use 316 Stainless Steel Tube and Wire, and You will be right.
No Rust
#8 _76lxJAS_
_76lxJAS_
Posted 20 March 2015 - 11:39 PM
once polished my 304 has never rusted?
welded with 316 though.
#9 _76lxJAS_
_76lxJAS_
Posted 20 March 2015 - 11:41 PM
Sorry about my bad typo up there ^^^^^^^^^^^^
not sure What happened there. :banghead:
Edited by 76lxJAS, 20 March 2015 - 11:42 PM.
#10 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 21 March 2015 - 12:12 AM
If you use 316 for exhausts it will eventually crack next to the welds.
#11 _76lxJAS_
_76lxJAS_
Posted 21 March 2015 - 12:17 AM
hmm thats going to suck then at some point. or blow should i say :D
#12 N/A-PWR
  • 9,595 posts
Posted 21 March 2015 - 12:25 AM
Yep, stainless welds does crack from vibration, but I would of thought an exhaust would of been OK.
#13 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 21 March 2015 - 12:46 AM
Its the constant expansion and contraction from the heat that does it.
316 is pretty hard and doesn't like it.
#14 N/A-PWR
  • 9,595 posts
Posted 21 March 2015 - 01:02 AM
OK, great Man Craig.
#15 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 16 May 2015 - 11:04 PM
321 stainless is the way to go but 304 seems to be what many use for non turbo stuff
http://www.burnsstai...21sstubing.aspx
