Hi all,
I'm looking for 2 of the plastic taillight sockets for my lj. Someone in the past has cut part of the plastic away for whatever reason, as there's no Lj's at the local wreckers I'm wondering if the same parts were used on Kingswood's or later Torana 's.
Here's the part numbers :
-7429955 =single wire / indicator
-7429820 = dual wires /centre lense in the lj taillight.
Ps if anyone has one of each they can spare I'd be interested in them. I'm removing the terminals from my damaged ones and swapping them over, there a bugger to get the terminal out of so cutting the wire off may be preferable if you have an old harness.
Thanks James
lj taillight sockets
jd lj
, Mar 29 2015 06:03 PM
4 replies to this topic
Posted 29 March 2015 - 06:03 PM
#2 _Bomber Watson_
Posted 29 March 2015 - 06:59 PM
The single wire/indicator one works.
Posted 30 March 2015 - 04:03 AM
Are you saying that one is compatible with other model Holden's from the same era??
#4 _sunburst73-xu1_
Posted 30 March 2015 - 06:05 PM
Hi James
PM your address to me and I'll spear you a harness,its been cut up abit but should have what your looking for.
cheers Dane
Posted 30 March 2015 - 07:26 PM
Will do, thanks for the offer Dane.
