Here is a list of the Engine parts, ect or close enough to get the idea.
They are genie extractors, was just thinking about my 2" twin exhaust system, that could be holding me back.?
Holden Torana Hatchback (22,000klm's)
Weight 1150kg
Blue printed and balanced 308 stroked to 355 "Harrop crank"
Runs unleaded fuel 98% octane
Worked L34 Heads
Yella terra roller rockers
Crane 304A cam
L34 valves, upgraded valve springs, Seal power push rods
10:1 compression
Holley HP 650 4 bbl D/P with Racing air filter (Heaps of Vacuum)
Elderbrock performer high rise manifold
I.C.E electronic ignition system with 8mm Leads
Full length Genie Extractors
Heavy duty 800cc gel battery
Big Alloy 500HP+ radiator, twin thermo fans
Full glimmer 10,000 rpm belt system
Heavy duty alternator
Twin 2" exhaust system with flow thru glass packed mufflers and balance pipe
Tricked stage 2 auto, tough trimatic gearbox with all German frictions
Alloy Gearbox oil cooler
More Stall Converter
Original LSD diff, 2.78 ratio with globe 5 star 13" Bathurst mags
Edited by Wings355, 01 April 2015 - 10:46 AM.
