Building a cross member/engine angle
7 replies to this topic
#1 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 31 March 2015 - 05:25 PM
Hi,
Just curious where to set the engine/transmission height would you just get the carb level, I'm just making a temp cross member till I buy a crs or dellows alloy one.
Holden 6 powerglide trans
#2 _Bomber Watson_
Posted 31 March 2015 - 05:28 PM
Yep they sit with the carb level stock.
Why not use a factory one as a temp though? Glide/trimatic/aussie 4 speed same same.
#3 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 31 March 2015 - 05:39 PM
The carb only sits level because the manifold is twisted or cast to make up for the 11deg? angle of engine/trans assy?
#4 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 31 March 2015 - 06:11 PM
Cheers bomber
#5 _Bomber Watson_
Posted 31 March 2015 - 06:41 PM
Yes the carb flange is twisted so the carb sits flat when the engine is installed, fail to see your point?
#6 Bigfella237
  • 4,377 posts
Posted 31 March 2015 - 07:17 PM
11° seems like a big angle, is that correct?
I thought most engines sat around 3° because that's the recommended operating angle for a universal joint?
#7 _Bomber Watson_
Posted 31 March 2015 - 07:29 PM
Ummm, no.
#8 Bigfella237
  • 4,377 posts
Posted 31 March 2015 - 07:32 PM
Ummm, no.
...to which part??
