Weber 34 ADM
_Muzzy_
Posted 10 April 2015 - 07:14 PM
I'm going to fit a 34 ADM weber from an XF, falcon as it offers a lot of advancement over my 38DGMS weber
My question here is of anybody who has one fitted
What jetting changes or modifications have you done or had done, to the carb to make it work for you
Posted 13 April 2015 - 11:49 PM
I think the 38DGMS is the perfect choice for a healthy 6cyl if your planning on using a 2BBL.
_Muzzy_
Posted 14 April 2015 - 08:26 PM
I have dyno run the car a number of times and have the 38 at its best, and the Economy isn't in the ball park to what I think it should deliver, so the 34 will go on and I will set it up on the dyno( handy to have one at work) and see how that goes, my main question is I think the secondary main is too big for a 173 at 2.10mm
_Muzzy_
Posted 24 May 2015 - 04:07 PM
_Muzzy_
Posted 24 May 2015 - 04:31 PM
Fresh acid cleaned and rebuilt weber
Has gained a few extra lines
Fuel return with 1mm restrict or
Vacuum line from manifold to AC solenoids
Line to AC compensator
Next job set up a factory Air filter and make a cover to hide all the electrics
Can someone tell is that the correct oil filler, that's what the car came with its a 4/74 LH
Edited by Muzzy, 24 May 2015 - 04:33 PM.
_Muzzy_
Posted 25 May 2015 - 06:22 PM
10hp gain from 1500 to 2500 then drops to same HP and then drops 5 hp from 3500 up, so I ended up 5 hp down at 4500 rpm
Much better AFR ratios on primary ( 14:1) and a nice fat mixture on WOT ( 13:1 )
_oldjohnno_
Posted 25 May 2015 - 06:31 PM
Sounds like a good result Brian. Do you use manifold heat? I'm a big fan of it for a daily driver, even if it does reduce the peak a bit. Very tidy engine bay you have there.
_Muzzy_
Posted 25 May 2015 - 06:46 PM
_SRV_
Posted 25 May 2015 - 11:20 PM
Looks great mate, the factory correct oil filler cap would be like this: http://www.superchea...Recommendations
_Macca97_
Posted 14 July 2015 - 06:41 PM
just fitted one of these to a 202, carb is from a 3.3 xe, so haven't bothered with jet changes, bolted it on, got fuel up, and started straight away, set timing and idle, runs great,
but my carb looks different to yours, ive got a few outlets/inlets that I have no idea what they are, vacuum ones are easy but I have others ahah
motor is only in a stand to play around with it, and im doubt weather its standard
