Just wondering what is the biggest tyre u can run with 120mm flares , on a 15"x10"rim with 5" backspace with standard diff length 11138167_10202900134144966_1207698160823620767_n.jpg 61.82K 5 downloads
biggest tyres u can run with flares
Posted 28 April 2015 - 12:57 PM
Posted 28 April 2015 - 02:55 PM
A 265/50 will fit easily enough once the guards are cut out, and look pretty good. A 285/40 gives a bit more width but they are expensive and in my opinion look a little strange in the lower profile/small diameter. A 295/50 can be made to fit with more cutting, or the car will end up sitting higher. Wider still is possible but tyres can be very difficult to get and probably best suit a wider wheel.
Posted 28 April 2015 - 05:41 PM
Posted 28 April 2015 - 09:16 PM
Dunno? But that offset should fill the flares good!
Posted 29 April 2015 - 12:51 AM
Posted 29 April 2015 - 03:11 AM
Posted 29 April 2015 - 06:51 AM
Posted 29 April 2015 - 08:37 AM
I have had 265's on the front with a 9.5 inch wheel and 5.5 inch backspace and just had clearance, plenty of negative camber. Flairs had the usual wedges taken out for maximum clearance etc.
Posted 29 April 2015 - 12:34 PM
Posted 30 April 2015 - 05:55 PM
Posted 30 April 2015 - 11:26 PM
be good if you could still get the 275/50 ta
Posted 30 April 2015 - 11:47 PM
Posted 02 May 2015 - 11:48 AM
Posted 02 May 2015 - 10:01 PM
Posted 05 May 2015 - 10:32 PM
Posted 10 June 2015 - 06:18 AM
#19 _hatch76_
Posted 12 June 2015 - 10:17 PM
Where did you get the 285's from
Posted 16 June 2015 - 01:19 AM
heavy on the pocket $500 each
Edited by BEANZ, 16 June 2015 - 01:32 AM.
#21
Posted 16 June 2015 - 01:30 AM
Posted 02 July 2015 - 06:20 PM
By plenty of negative camber, how much are you talking? More than -2?
#23
Posted 02 July 2015 - 10:12 PM
I know it looks tough having a massive rear tire and big dish rim, but don't you guy's worry about the track difference front to rear and how shit it handles with a larger track rear ?
I've just fitted 245/40/17's all round on 8 inch rims..... it does rub at lock at the front on firewall and chassis rail but its not that bad(but does suck! am considering modifying rail and firewall a little). This has bought the track front to rear to ~5mm from the same and the handling difference from my old staggered 10" rear rim and 8" front is very welcomed with horsepower, much nicer on turn-in and oversteer
#24
Posted 02 July 2015 - 11:25 PM
From memory, with the larger rear A9X flares, there was a significant disparity in the front/rear wheel width (hence track) and yet they seemed to handle ok?
#25
Posted 03 July 2015 - 08:25 AM
Personally I like them to be reasonably even for aesthetics if nothing else, but it is nice to have them similar to make suspension setup easy too. My front track is actually 5mm wider than the rear, but the rear tyres are 20mm wider.
