The bad oil change.
84 replies to this topic
#51 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 10 February 2021 - 08:46 PM
Oil pump gears?
That would be a helluva trip to get from the pump housing to the sump ...
#52 Oversteer
Oversteer
  • 244 posts
  • Car:LH SLR5000
Posted 10 February 2021 - 09:52 PM
Are they needle bearing bits on the plug ?
Aren't many places they can come from.
#53 Heath
  • 18,309 posts
Posted 11 February 2021 - 10:16 AM
The motor or the thread?? :)
LOL
Rome wasn't built overnight.
This motor apparently didn't munch away at itself to the point of throwing a leg out of bed in a hurry, either.
#54 rexy
rexy
  • 3,587 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 12 February 2021 - 03:15 PM
Well the autopsy has got a bit further along.
Attached File  E4A0C7A4-CE38-4166-8C7F-5B16D32C1088.jpeg   139.22K   8 downloads
At first glance I still couldn’t see a problem but as some of you will know, the passenger side cam lobes are partly obscured in a BBC.
So I removed the rocker gear to pull the lifters and cylinder 7 is the problem. Couldn’t pull the lifter pair and looking with a mirror showed the roller tip was no more.
Attached File  AD387C18-2ABB-47A4-BD15-E8AB8375FE75.jpeg   110.98K   13 downloads
Kinda hard to see but interestingly the pin holding the roller is still there so the roller itself has disintegrated. Oddly the cam lobe looks good but only a little bit is visible. No doubt it will look worse in the full light of day.
Attached File  B24E2012-CFAE-4D5D-BAB9-509FF0E4AA17.jpeg   224.96K   8 downloads
The big bit seems the right curvature. Presumably the rest is still hidden in the sump.
Although I could probably fix the broken bits and go again the motor is nearly ten years old and probably deserves a proper once over so I’m going to pull it and send it to the experts. Despite its issues it’s been a fun thing to drive.
Should have a bit of time to get most of it done given we are yet again locked down thanks to Chairman Dans inability to run a chook raffle, let alone a quarantine system. If only he hadn’t crowed about Victoria’s system being the best in the universe a mere week ago....
Is this an opportunity to make even more power for the uterus?
#55 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 13 February 2021 - 07:56 AM
Which car is it in rexy?
#56 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 13 February 2021 - 12:00 PM
My old HQ ute.
#57 yel327
  • 13,081 posts
Posted 13 February 2021 - 02:52 PM
Jealous! I have a GenV 454HO and a MarkIV 427 here, yet to find a car to put either in. Hope yours doesn’t have too much damage other than the cam/lifters.
I’d cut Dan some minor slack, all of the State Premiers must be under massive pressure. Not a job I’d take on for twice their salary!
#58 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 13 February 2021 - 09:05 PM
The big block was put in and engineered 25 years ago, back when it was easily approved.
Dan is a genuine never had a real job goose. We would happily swap for Gladys!
#59 yel327
  • 13,081 posts
Posted 14 February 2021 - 07:53 AM
I have a GTS327 to put the 427 in, but life gets in the way.
No deal, You can keep him. But I still wouldn’t want his job no matter the $ paid.
#60 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 22 February 2021 - 03:30 PM
Well it’s out. Time to find someone to give it a once over.
Attached File  370917C1-1B90-46CD-9390-847D6E9EE9BA.jpeg   200.07K   10 downloads
#61 LXCHEV
LXCHEV
  • 3,510 posts
  • Car:'76 LX - 383 Chev
Posted 22 February 2021 - 07:47 PM
And may it return with a dirty big 6/71 sitting on top!
#62 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 26 February 2021 - 07:46 PM
I wish! One of these days I will get around to having a blown big block car.
Years ago there was a guy who built a few rootes supercharged cars with everything under a stock bonnet. I think he had an XW or XY in Street Machine?
#63 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 26 April 2021 - 04:24 PM
Post mortem.
Not too bad!
Attached File  18FC743B-FCF9-400D-8B61-A052641E99AB.jpeg   126.48K   8 downloads
Attached File  4954D5EF-AEC2-4A3E-9086-0F3E2FDAD3D3.jpeg   170.15K   6 downloads
Attached File  D8CC6748-02BE-48DF-BA2C-17A978FC1DFD.jpeg   78.15K   6 downloads
Attached File  D8691D01-6A15-4486-86DD-AD900CD2D9C9.jpeg   87.9K   6 downloads
Attached File  A405DEF1-B308-431C-AC3B-94FF868A0587.jpeg   159.98K   6 downloads
Heads, crank, rods and pistons all OK. The only issue is that it looks like the yokels that built it were a bit “how ya goin” with the cylinder prep so it needs a minor rebore/hone to get everything perfectly round AND they used the biggest off the shelf piston they could find.
So I’m gonna have to wait for custom pistons and rings from the mighty US of A.
Oh well!
#64 Redslur
Redslur
    Has been Torana owner
  • 3,532 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 27 April 2021 - 12:44 PM
Could have been worse I guess :-)
#65 myss427
myss427
  • 1,636 posts
Posted 27 April 2021 - 01:30 PM
I had a lifter retainer break on the dyno on mine a few months back, just wrecked a roller lifter and cam only. Problem with roller lifters is the don't like idle, need the extreme style with the oil pressure hole to the the roller to keep them alive.
#66 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 29 April 2021 - 05:28 PM
What brand are they Rexy?
#67 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 29 April 2021 - 10:26 PM
That failed lifter is a Howards.
Still deciding on what to do now it’s all apart.
#68 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 30 April 2021 - 10:19 PM
Ran across a couple of legends in my travels today - George and Ray Haddad.
True gentlemen and legends of the scene. Watching their orange HQ with the blown 355 plastic going hard in the street drags at the Easternats was a delight. It was always full of passengers and today I asked George why? The need for traction was more important than the weight cost of the passengers. It was one fast Lebbo express!
Attached File  655143E9-8735-40DB-8707-006CE2E3CB74.jpeg   475.35K   6 downloads
Wheels up action.
Attached File  6742B241-D93A-4349-9A3B-A1AEF143E871.jpeg   422.58K   5 downloads
Quick.
Fully engineered and registered.
Attached File  68A11827-61E1-4F16-AC7A-FF9F0F88E4B5.jpeg   332.31K   5 downloads
Who says you can’t have a 9 second street car?
#69 gtrboyy
gtrboyy
  • 3,137 posts
Posted 01 May 2021 - 12:37 AM
Very cool car...didn't driveline end up in a customer's vl brock grp 3/signature?
I kind of liked vn commo they did before that but moreso the lc coupe buildup they did that was covered by streetcar mag
#70 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 03 May 2021 - 03:55 PM
George told me he took one very keen prospective buyer for a drive and when he gave Ir a bit of a squirt the passenger reached hard for the non existent Jesus bar.
George told him it wasn’t the car for him and declined to sell it to him.
He did say that when it was sold it had a tamer holden in it that was “blower ready” when the new owner was ready. He hasn’t come back for the blower yet!
I have never seen a car that size with only 800 hp move that fast off the line on a street surface.
#71 gtrboyy
gtrboyy
  • 3,137 posts
Posted 03 May 2021 - 06:20 PM
Tuning,tyres & suspension have come a long way since then...same driveline/car with tp block they'd have it in the 8's & drag challenge friendly
Loved seeing ol' kingies lift 1 wheel in air other wheel still on ground twisting like crazy as a kid.
Could have been worse selling the car to someone who wasn't afraid of it....
Edited by gtrboyy, 03 May 2021 - 06:21 PM.
#72 yel327
  • 13,081 posts
Posted 03 May 2021 - 06:32 PM
It’s a coupe isn’t it? Doesn’t look like a sedan on my phone.
#73 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 03 May 2021 - 10:51 PM
George did say that if he was going to chase more power then he would have built a chev. Didnt say what configuration though.
He was certainly making plenty of power for Craig Gerdes who was running a Haddad built blown 572 BBC at the time.
The orange Monaro was very street friendly. Driven during the week with the cage bolted in on Friday before it was driven out to Calder for some racing.
Edited by rexy, 03 May 2021 - 10:54 PM.
#74 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 04 May 2021 - 08:21 AM
Attached File  Haddad.PNG   622.35K   3 downloads
#75 yel327
  • 13,081 posts
Posted 04 May 2021 - 08:56 AM
Thanks Laurie, I thought it was a coupe. Just questioned my eyesight when it was suggested it was a "Kinga" above so must have been a sedan.
