coil overs
#1 _Marco72_
Posted 14 May 2015 - 10:48 PM
Posted 16 May 2015 - 08:58 PM
Rear spring rate can vary a bit between cars, hp and tyre choice, seen anywere between 250pds to 350pds been used.
250-300 prob a start point, making sure the rear end is as free as can be in articulation greatly affects the rate and how it drives on the track
#3 _Marco72_
Posted 16 May 2015 - 11:10 PM
#4 _Pro308olh_
Posted 18 May 2015 - 05:45 PM
Ive put these little beauties in
#5 _Marco72_
Posted 18 May 2015 - 07:02 PM
Posted 18 May 2015 - 07:27 PM
Depends how fast you want to go.
3/4 rose joints are a bit overkill but won't hurt it.
Just checking the original upper arms are disconnected or have been made useless.
With a 3 link you will prob want a 300-350pd spring in rear to start with, iv played with that sort of setup on my car, the off the shelf spring rates, when used in a 3 link were all wrong, made I big difference to car.
Next step for me was going to be change shocks to a good quality coilover.
You want the rear roll centre about 100mm higher than front to start with.
AND have to watch the diff housing, with a 3 link, due to loading, they need to be braces as I can bend the housing.
When it's setup, works great tho.
#7 _Marco72_
Posted 19 May 2015 - 08:02 PM
#8 _Marco72_
Posted 20 May 2015 - 06:44 PM
#9 _Marco72_
Posted 20 May 2015 - 06:46 PM
Posted 20 May 2015 - 07:03 PM
Just click on the blue "More Reply Options" button below, "Attach Files" and upload from your PC
You may have to resize them if they're too big?
#11 _Marco72_
Posted 20 May 2015 - 07:16 PM
#12 _Marco72_
Posted 20 May 2015 - 07:20 PM
#13 _Marco72_
Posted 20 May 2015 - 07:22 PM
Posted 20 May 2015 - 07:25 PM
Thank God for that, I thought my eyes had gone...
Definitely looks like a setup I'd like to see more of (or more clearly) though?
Posted 20 May 2015 - 07:26 PM
Looks like your camera had a few beers before taking that.
#16 _Marco72_
Posted 20 May 2015 - 07:39 PM
#17 _Marco72_
Posted 20 May 2015 - 07:43 PM
Posted 21 May 2015 - 09:21 PM
Should notice a big difference how the rear squats too, instead of lifting the rear up(standard rear) under power it pushes the rear down, gets a bit more weight transfer.
#19 _Marco72_
Posted 21 May 2015 - 10:56 PM
