175 Leaking from mixture screw
4 replies to this topic
#1 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 23 May 2015 - 03:40 PM
Hi,
One of my carbs is leaking from the 5/8 nut that the mixture screw screws into.
Is this just a rubber O ring?
If so can someone recommend where to source a kit or just the O ring
Cheers Brian
#2 _Agent 34_
_Agent 34_
Posted 23 May 2015 - 05:39 PM
if your talking about the one under the bowl that raises and lowers the main jet then yes it's the O ring.
just get three new kits as if this one is gong then the others are close behind.
Ring up FABRE australia and they have kits - but there in sydney.
good luck or fle bay
Edited by Agent 34, 23 May 2015 - 05:39 PM.
#3 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 23 May 2015 - 06:02 PM
Thanks Grants thats exactly what Im after.
Cheers Brian
#4 _Agent 34_
_Agent 34_
Posted 23 May 2015 - 06:50 PM
No problems brian.
just a tip don't put any carby cleaner anywhere near the diaphragms as they distort.
Probably wont hurt changing them as there probably old as well.
but hey " if its not broken don't fix it" otherwise you will have to fix something you will break in the process LOL
the screws out of the dashpot's also get stuck or are hard to get out if they haven't been apart for awhile.
Edited by Agent 34, 23 May 2015 - 06:52 PM.
#5 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 23 May 2015 - 09:17 PM
Hi Grant,
Thanks for the tip
Cheers Brian
