Hi,
Had a good day at the above today, with Steve ( Dodgey ).
Unfortunately, both cars suffered some minor issues.
Steve sorted his out and powered on.
My LJ seemed to just miss and fart more as the day went on.
Woundnt idle for sh$#t, and was backfiring thru the Webers??...all of them, in a random pattern
After getting home and doing the obvious, i.e. draining my fuel tank and refilling with fresh fuel, as the old stuff was a month or two old, ,checking plugs, doing a comp.test, checking fuel bowls for crap, checking distributor, coil, leads etc etc,,,,ending up finding my new Bosch electronic dizzy was a bit random on the advance.( this dizzy had done several club / track days without issue)
This dizzy is only a few months old,,,looks like it has had a failure in the advance thingo??
Note the ""loose"" plastic bit flapping around (on the end of the red screwdriver)??
Anyone else had this type of issue?....I assume its a warranty / failure claim.
Ta
Col
p.s. loosening the dizzy off and and twisting it a bit in the block resulted in the car running just fine, so happy it is the root cause of the the current issue.
