I bought a QL block and the block had a X stamped before the QL
the bore is standard.
the stamped X is out of line and is deeper than the standard holden offering numbers
Any ideas on this.
will reduce photo and post.
C
Posted 29 May 2015 - 06:41 PM
Any ideas on this.
C
Posted 29 May 2015 - 06:46 PM
Posted 29 May 2015 - 07:17 PM
ADR27A 202 suit auto transmission.
Posted 29 May 2015 - 07:41 PM
wot that would be XXX
i need to stamp it a few more times !
Edited by Agent 34, 29 May 2015 - 07:42 PM.
Posted 29 May 2015 - 07:48 PM
X = Export Maybe ????????????
Or a Special Donk etc ?????
AL
What's the cast date, 1977?
Posted 29 May 2015 - 07:49 PM
Yep, July '76 onward red 202 with auto trans only, the cast date should confirm.
Guessing XQL8010xx should be around September/October '76?
Posted 29 May 2015 - 07:50 PM
Posted 29 May 2015 - 07:56 PM
FUK u blokes are fast.
AFAIK it was from a HQ one tonner with a low comp head.- saw the ute it came out of from the country.
I will check the cast date BUT have never seen the X
bloody hell , ill have to go down the garage now in the cold and check !
Edited by Agent 34, 29 May 2015 - 07:57 PM.
Posted 29 May 2015 - 08:09 PM
here are the marks
5 near side
8 off side
Posted 29 May 2015 - 08:14 PM
I don't know why but for some reason GMH used Holden engines in auto LX 6cyl ADR27A Toranas, whereas the manual 6cyl ADR27A Toranas got Torana engines.
The X was stamped in the assembly plant to denote it was going in a Torana rather than a Holden. The rest of the number was stamped at the engine plant at Fisherman's Bend. It was done at the same time and for the same reason that a Statesman engine was stamped with 11 or 12 - to denote it was in a Statesman rather than a Holden.
Edited by yel327, 29 May 2015 - 08:14 PM.
Posted 29 May 2015 - 08:16 PM
10J6 = 10th September 1976
Posted 29 May 2015 - 08:25 PM
geez you know some stuff Yell!!
