Console-less Gearshift Boot Ideas
15 replies to this topic
#1 Heath
  • 18,309 posts
Posted 07 June 2015 - 11:00 AM
If you're running no centre console and you're start from scratch with a gearbox/shifter (T56/TKO/Toploader/T5/W58 etc. - something that Holden never put in an old car) what recommendations do you have for a shifter boot?
Anyone have good photos of what they've done/what they've seen? Need something that'll seal out the under-car smells & noises a bit, and look good on the inside of the car, and also attach gracefully to a floor with nothing but carpet around it.
Photos of good setups would be good, but even better would be seeing what they look like pulled apart, product links? how they mount up and so on.
Edited by Heath, 07 June 2015 - 11:02 AM.
#2 yel327
  • 13,081 posts
Posted 07 June 2015 - 01:34 PM
Have a look at what GMH did with 4spd in HK-HG ute and van. These sit on a boss though and are the only floor shift on any of these apart from early in HK there was also a floor shift setup on HK Belmont sedan and wagon where there was a little round boot with a round HR style shifter.
The only other floor option that I can think of is what a HQ-HZ commercial had with bucket seats - these had a straight stick (not bent like a bench seat car). Lots of the HX-HZ commercials had console shift 4spd though, it was HQ-HJ where there was no console shift for commercials outside of Sandman so finding images will be hard. Have a look at L34 as well.
#3 _76lxJAS_
_76lxJAS_
Posted 07 June 2015 - 02:54 PM
i made up mine by heating up some 4mm perspex and bending it to shape to match the floors profile done in 2 pieces.
also a universal shifter boot from ebay cut to the length i wanted,
all trimmed and finished with no screws showing at all,,
where the bolt is in my pic goes through both pieces into a nutsert on a metal bracket the attaches to the transmission tunnel.
as they are round in a sence no need for anymore than one bolt, it doesnt move or slide around at all..
just 1 small slit in the shifter boot to access where the bolt is..
if that makes any sense?
i dont have a photo of it finished but if you want to see it let me know and ill go out and photo it for you..
Edited by 76lxJAS, 07 June 2015 - 03:02 PM.
#4 rodomo
  • 17,998 posts
Posted 07 June 2015 - 08:46 PM
Speco.
http://www.speco.com.au/accboots.html
#5 76lxhatch
  • 7,152 posts
Posted 08 June 2015 - 07:46 AM
^ That's what I'd do, period look and the surround looks fine just screwed down with stainless screws
#6 _LS1 Hatch_
_LS1 Hatch_
Posted 08 June 2015 - 09:59 AM
To help with sealing things, maybe think about running a smaller inner boot and then a nicer outer boot?  I know here back when at least some cars had a rubber boot that would seal moisture and what not (that was sort of flat)  then the larger boot over top.
I have a console, but I run 2 boots as well.. I picked up an SFI approved boot that is like fire and everything resistant (believe it has nomex in it as well as a foil-ish inner layer) that I use mounted to the floor itself then used a suede black with red stiching one..just like in the pic above) that I mounted to a trim ring on the console.
Might be a bit over kill but nice to have a good quality boot I figured at least between me and the "outside" and if I hadn't been running a console I would have just left the lower boot as it is and maybe just made a nice aluminum trim ring where it comes through the carpet?  (I attached and sealed the boot to the floor and slide the carpet over the top)
Kinda see it a bit in the this shot too..
#7 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 08 June 2015 - 10:59 AM
I did this on The Truckster.
A generic rubber boot from Spectrum Rubber for about 20 bucks and a 3mm stainless plate that I plasma cut and drilled a few holes in.
#8 Bigfella237
  • 4,371 posts
Posted 08 June 2015 - 11:09 AM
Jeff makes a good point about stopping a potential under-car fire from getting inside the cabin, makes sense although seems rarely done by the manufacturers.
#9 _LS1 Hatch_
_LS1 Hatch_
Posted 08 June 2015 - 11:12 AM
Dual boots seems common though in the OE,  know the 6 speed late model Camaro my drivetrain came from, along with the one I owned and drove for a couple years... use a rubber lower boot and leather (or leather-ish,lol)  upper.
Probably overkill on my car, but what the heck...8 piston Brembos are overkill too but that didn't stop me..ha ha.
#10 ls2lxhatch
  • 5,332 posts
Posted 08 June 2015 - 11:35 AM
I like the Lokar design with a bezel that seals the boot to the shifter.  If you only want the book part way up the sifter you can use an o-ring bezel.
I would also use a rubber boot on the inside.
http://lokar.com/pro...zels-boots.html
Edited by ls2lxhatch, 08 June 2015 - 11:49 AM.
#11 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 08 June 2015 - 03:52 PM
Check out the L34 option too. I know the 1900 opel LHs had that similar 70s look. Rubber rectangular design.
#12 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 08 June 2015 - 06:57 PM
If 8 piston Brembos don't stop you, you have problems!
#13 _76lxJAS_
_76lxJAS_
Posted 08 June 2015 - 09:15 PM
boots with metal rings and exposed screws just look cheap and to easy  i think,
to many of them out there just different shapes sizes etc,
#14 hawk
hawk
  • 2,143 posts
  • Name:steve
  • Car:UC Torana
Posted 13 June 2015 - 09:29 PM
Im going to have to do something similar with my 4 speed. How were the standard boots setup?
#15 Heath
  • 18,309 posts
Posted 15 June 2015 - 02:33 PM
I was always intending to double bag that rod that I regularly have my hand on.
The car already had this in it, and it's not awful but thought there may be some good ideas other people had seen. It bolts down obviously but the carpet actually tucks in over the bolted flange neatly. I may just keep it, as the new gearbox lines up with the old hole beautifully. But probably put something else over the top as well, once I find something I really like the look of.
Edited by Heath, 15 June 2015 - 02:35 PM.
#16 _76lxJAS_
_76lxJAS_
Posted 16 June 2015 - 10:50 AM
This is what mine above came out like finished. Not everyone's cup of tea but is what I wanted. No metal ring of bolts showing..
Edited by 76lxJAS, 16 June 2015 - 10:51 AM.
