LC K Frame off center. Effing outrigger bushes!
Posted 14 June 2015 - 08:16 PM
http://www.superpro....-999500551/vid-
Think I have talked myself into fixing it as I type this, but what do you guys think am I being too fussy, leave or fix?
Steve
Posted 14 June 2015 - 08:49 PM
you're right, its not the easiest of jobs.......any change they may even themselves up after a drive?....or you want to sort it before then?
#3 _Bomber Watson_
Posted 14 June 2015 - 09:41 PM
Is the K frame straight?
Posted 15 June 2015 - 12:31 PM
The four main bolts on the chassis rails are all located pretty much spot on visually.
I think I will play it safe while the engine is not in and drop the frame and replace the rubber ones with the superpros and carefully do it all up and ensure its aligned.
Posted 15 June 2015 - 12:44 PM
If you are whipping it out again Id be checking and comparing everything I could from side to side to make sure everything measures up spot on.
I doubt swapping the type of bush you use will fix your issue.
Posted 15 June 2015 - 01:05 PM
#7 _walpolla_
Posted 15 June 2015 - 07:27 PM
I reckon that will square up ok. You have got the top 4 bolts still loose I presume? If not ,loosen them, tighten the outriggers and I think you will find it will even up.
These cars were not that precise when new, let alone after 40 years of kerbs, potholes, small prangs and such.
You won't regret using the rubber compared to the urethane.
regards,Rod.
Edited by walpolla, 15 June 2015 - 07:29 PM.
Posted 15 June 2015 - 09:06 PM
Looking back at the pics I just cleaned up the cracks dropped a bit of weld in then plated them up. Maybe they moved a little when it was cracked and being driven around.
http://www.gmh-toran...tr-build/page-2
I did back off the RH side and tried to tighten the LH side but it didn't budge. I didn't however back off the four chassis bolts. I will give that a try. I will back everything off, maybe give the RH side a nudge with the pry bar and see if it comes good. I also tightened the RH side first so I may have overdone it and didn't do them up as evenly as I should have.
Yeah makes sense Rob thanks and I know what your saying about the eurethane stuff I do prefer rubber myself, these things were harsh enough with rubber! Will go the eurethane if all else fails.
Steve
#9 _walpolla_
Posted 18 June 2015 - 08:46 PM
Any progress?
Posted 19 June 2015 - 11:08 PM
Posted 21 June 2015 - 10:32 PM
#12 _Bomber Watson_
Posted 22 June 2015 - 09:02 AM
Posted 27 June 2015 - 07:38 PM
Do you know what the measurement should be between the two outrigger arms. I have a spare front end but it has been hit so isn't a good reference point.
Steve.
#14 _Bomber Watson_
Posted 27 June 2015 - 07:54 PM
NOt off the top of my head.
A real good start would be to simply measure from say the left hand rear chassis mount hole to the left hand outrigger hole, do the same on the right, then do cross wise so left hand rear chassis mount hole to right hand outrigger hole, this wont tell you its correct but will tell you if its close to square.
I do have a spare x member here, actually shoved it in a hole so its hard to get to just this arvy whilst I was havint a tidy up, didnt even think about your issue at the time, and i've never measured it so cant say if its straight either tbh.
Start with the above, see where we get from there.
#15 _2ELCS_
Posted 27 June 2015 - 09:45 PM
According to the workshop manual it should be 27.76 inches to the outside end of the arms .
Whatever that is in metric ????
#16 _Bomber Watson_
Posted 27 June 2015 - 09:59 PM
705.1mm by my calculations.
#17 _2ELCS_
Posted 27 June 2015 - 10:06 PM
Jelly bean numbers DJ ?
Edited by 2ELCS, 27 June 2015 - 10:07 PM.
#18 _Bomber Watson_
Posted 27 June 2015 - 10:19 PM
Na just the units everyone on the planet bar old Cunning Stunts and Americans have used since the mid 70's.
#19 _2ELCS_
Posted 28 June 2015 - 09:02 AM
I'm allowed to ?????
#20 _Bomber Watson_
Posted 28 June 2015 - 11:58 AM
#21
Posted 28 June 2015 - 12:33 PM
#22
Posted 12 July 2015 - 12:24 PM
Ok all worked out in the end. Dropped down the cross member, and pulled out the outrigger bushes. As you can see from the pic below the offending side was a bit damaged from trying to get it in, and it literally fell out when I went to pull it out. The other side was very secure and I had to destroy it to get it out.
Still took a lot of patience to get the Superpro's in but it was easier than the rubber ones. Probably because the steel bush is moulded into the rubber ones. Bit of stuffing around with the home made press, bit of jiggling with the screwdriver to feed the ends in evenly and in they pop.
Then had to push in the bush, same deal lots of grease and in she went.
Getting it all back in I greased up the chassis and outside of the outrigger bushes. I then put the jack under the crossmember with a large redgum block that I used as a pivot to angle the outrigger arms in. Using the paintscraper trick to guide the outrigger bushes which someone else mentioned on this forum worked a treat. Also this time I did everything kneeling in the engine bay which made things a little easier. Then used a jack to raise and align each outrigger arm with the bolt holes.
Did some measurements beforehand and all seemed to be square. Took my time carefully tightened everything up slowly and in sequence. Torqued everything up to the correct specs and she is dead center in perfect alignment.
I think the first time I rushed it and dodged up that one outrigger bush. Then over tightened it on that side and it popped out, so was user error!.
I hate having to do things twice but thats what you get when your impatient.. Now all there is left to do is everything else.
#23 _Bomber Watson_
Posted 12 July 2015 - 05:59 PM
Yay!
