I would love to see accurate measurements like that of LH/LX Torana chassis clips, I would be happy to do all the CAD work if somebody has the measurements? I was gonna do them myself but there's too many things in the way on a complete car, you'd need a bare shell, possibly on a rotisserie but I'm not sure if that would cause any distortion?
I want to CAD a front K-member plus upper & lower control arms as well but again. I don't have any bare examples to measure up.
I was also concerned about manufacturing tolerances, ie every car going together slightly different, but I thought everything could be "adjusted" to suit the official chassis checks as we went along?
should be able to find an engineer in nsw to cert the departure angle from the exhaust as VSB14 is an advisory document still here.
Ewww, I really don't want to open this can of worms again, and certainly not in this thread, but the departure angle rule is very much open to the individual engineer's interpretation, some may accept the exhaust as part of the "OEM permanent body work", some may not, but this has been argued to death on this forum several times at least and I'd really rather not go there again!
Re GrabCAD: This may be a limitation of the free Autodesk 123D software I'm using, but it seems to only import files in a *.svg format and the files on that website are *.stp or *.stl or *.SLDPRT, none of which this software seems to accept?
Is there a way to convert file formats?
I can see some advantage in being able to share files here, is there some common format or do all the different software packages just do their own thing?
