Your sealing problem could be in the ports of the distribution block.
When the tube nuts are tightened either the flare on the tube has to deform to seal on the convex seat in the distribution block or the convex seat in the distribution block has to deform to seal against the flare on the tube or both.
As the distribution block is alloy and the flare is steel then it is the convex seat in the distribution block that will deform. If the convex seat was badly deformed by the previous brake lines then you can have difficulty getting it to seal with the new brake lines. Brake lines made out of the softer bright zinc finish bundy tube or cunifer bundy tube will be easier to seal. If you look at the convex seats in the distribution block you will be able to see the impression left on the convex seat by the flare on the tube.
The distribution block has two separate circuits with a brake fail switch between them to sense a difference in fluid pressure between the two circuits. The master cylinder will have a front brake circuit and a rear brake circuit. The front brake circuit of the master cylinder is typically the one with the largest reservoir. It can be the front or rear depending on the master cylinder design.
The front circuit has three ports as long as you have the front left, front right and front brake circuit of the master cylinder connected to the ports is does not matter what order they are in.
The rear circuit has two ports, rear brake master cylinder in and rear out, again the order makes no difference.
You appear to have the wrong brake fail switch screwed into the distribution block. The plastic switch only suits the late LX distribution block proportioning valve. The correct switch for your distribution block is the single pin metal switch. If you examine the switches you will see the metal switch has a longer and thinner pin. You can machine up a pin extension for the plastic switch if you want to use it with the distribution block.
The dual pin plastic switch was introduced to meet an ADR31 that required a separate brake fail warning light. One of the pins is the earth for the warning light and the other is a switched earth from the ignition switch for testing the warning light circuit and globe.
Edited by ls2lxhatch, 18 July 2015 - 02:06 PM.
