LX sedan rear exhaust hanger brackets
14 replies to this topic
#1 _mint jelup SLR5000_
Posted 15 August 2015 - 01:33 PM
Any chance someone could post a couple of photos showing the rear tail pipe hanger brackets please. Need shots of where and how they attach to the chassis and the exhaust if possible.
Also has anyone purchased new ones and could direct me to a supplier ?
#2 hanra
  • 10,831 posts
Posted 15 August 2015 - 02:42 PM
The LH parts catalog lists the same tailpipe support clamp for 6 & 8 cyl engines and a different part number for 4 cyl engines.This would indicate that the 6 & 8 cyl tailpipes were the same diameter.clamp_LH-1.jpgTailpipe listingtailpipe.jpg
#3 LXM21
LXM21
  • 450 posts
Posted 17 August 2015 - 06:31 PM
You will struggle to get them new.
Seen on ebay occasionally, although the leather/fabric piece can a bit worse for wear.
#4 _mint jelup SLR5000_
Posted 17 August 2015 - 06:42 PM
Looks like I can get them from Parra exhausts in NSW. Just going through the process now, hopefully they're a winner
#5 toryman76
toryman76
  • 1,082 posts
Posted 02 May 2016 - 10:00 PM
I'm just going through the same process of trying to source these. Did you have any luck? Any idea if you can get the round clamp (item 13 above) in different sizes? My pipes are 2 1/4"
#6 rodomo
  • 17,997 posts
Posted 02 May 2016 - 10:05 PM
Not hard to make?
#7 dattoman
  • 16,470 posts
Posted 02 May 2016 - 10:08 PM
#13's were avail in
1 5/8"     GMB127
2"           GMB130
1 3/4"     GMB131
#8 toryman76
toryman76
  • 1,082 posts
Posted 02 May 2016 - 10:36 PM
Making my own was plan b. Figured if I could buy something off the shelf it would save some time. I'll have to pull out my 6cyl one to copy and 'upsize'.
#9 toryman76
toryman76
  • 1,082 posts
Posted 03 May 2016 - 10:16 PM
I know this might be a lot to ask, but does anyone have an original one that is handy to them to quickly run a tape/ruler over? I have drafted one up but only by eye from the parts manual as I don't have access to the car during the week. Here's what I have come up with so far, no holes for the rubber loop because I am not sure whether to bolt or rivet it on yet.
I was also thinking of making up an original style clamp but to suit my 2.25" pipes, something like this.
#10 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 04 May 2016 - 06:55 PM
Im sure I have one in the shed , just have wait till tomorrow so I fish it out.
#11 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 05 May 2016 - 11:05 AM
Sorry, I dont have any tailpipe clamps to reference.
Also the correction, on the the rubber loop, its 250mm outside circumference Not outside diameter.
Edited by fuzzypumper, 05 May 2016 - 11:09 AM.
#12 toryman76
toryman76
  • 1,082 posts
Posted 05 May 2016 - 03:56 PM
That's fantastic fuzzy thank you!! No worry on the clamp I will just work backwards from these measurements to where my pipe sits. Thanks again very very helpful.
#13 308 Sunbird
308 Sunbird
  • 965 posts
  • Name:Stuart
Posted 06 May 2016 - 04:13 PM
Thanks Fuzzy I've got to make some of these as well- very helpfull.
#14 toryman76
toryman76
  • 1,082 posts
Posted 22 May 2016 - 09:50 PM
Thanks to Archie (fuzzypumper) I now have a complete set of tail pipe brackets. I used bolts to fasten the rubber to the bracket in lieu of the pressed studs. I bought the rubber from Clark Rubber it is 50mm wide 6mm thick 230ish long each so I bought 500mm. This was the close enough to the original size for me. The brackets I had laser cut and pressed by a supplier at work. The round clamp I had laser cut flat and had the simple 100° bend done then formed the round shape over a 60mm OD heavy wall pipe using a G-Clamp and a hammer to work it around. Was a lot easier than I thought. I also had some custom hanger brackets made up for near the mufflers. If anyone is interested I can help with these but I did have to modify one side to suit as the existing exhaust was different left to right relative to the hanger bracket off the trailing arm.
Thanks once again guys. If anyone wants more photos or drawings for the parts I had made just let me know.
#15 Kiwi_SLR
Kiwi_SLR
  • 9 posts
  • Car:LH SLR
Posted 23 June 2016 - 07:16 PM
Thanks guys,
i bought some universal hangers and they're cactus.  I'll use these drawings and make some up
