Brake pedal pivot ratios for LH & LX?
Posted 22 August 2015 - 07:15 AM
Posted 24 August 2015 - 10:46 PM
For
LH/early LX, the pin is 63mm below the pivot and the pedal is 390mm long so 6.2:1 ratio.
and
LX/UC the pedal is the same 390mm long and the pin is 71mm from the pivot so 5.5:1 ratio.
M@
Posted 25 August 2015 - 10:44 AM
Posted 25 August 2015 - 07:14 PM
Q. I guess this why the push rod on the booster on later toranas have a bent down end to match up with pin been lower or further away from the pivot point on the pedal?
Posted 25 August 2015 - 07:36 PM
Yep - spot on.
I meant Late LX/UC for the second one too ^^^
