A9x thremo fan bracket
9 replies to this topic
#1 2403jam
2403jam
  • 193 posts
  • Name:2403jam
  • Car:LJ GTR and LX SLR
Posted 24 August 2015 - 07:45 PM
Hi guys im after a picture of the bracket that holds the thremo fan on a a9x or if anyone wants to sell one be more than happy to buy it any help will be good thanks
#2 Bigfella237
  • 4,371 posts
Posted 24 August 2015 - 08:15 PM
Is this the one...
Attached File  A9X Aux Fan.JPG   124.65K   5 downloads
#3 2403jam
2403jam
  • 193 posts
  • Name:2403jam
Posted 24 August 2015 - 08:17 PM
Your a champ big fella thanks going to make one if i cant buy one thanks havea good nite
#4 Shiney005
  • 9,033 posts
  • Car:Toyota Mirai
Posted 25 August 2015 - 09:28 AM
So was the A9X fan run by a Lucas motor like the wipers and heater fan?
#5 yel327
  • 13,081 posts
Posted 25 August 2015 - 11:03 AM
Not sure, but I can tell you that a pair of fan motors with the same blades as the A9X mounted in front of a 3 row HZ 6cyl radiator (same as A9X but opposite spouts) doesn't keep the car all that cool. Mine used to overheat in traffic, was just enough for a 6cyl but I doubt it'd be all that effective on a V8.
#6 TerrA LX
Posted 25 August 2015 - 01:26 PM
I used to run the single A/C fan, no other fan, as per A9X in a 308 HJ th400 with no cooling issues what so ever.
#7 myss427
myss427
  • 1,636 posts
Posted 25 August 2015 - 02:00 PM
What that picture does not show is the attachment ring with 3 holes, that goes between the fan and motor, its welded to the bracket.
#8 2403jam
2403jam
  • 193 posts
  • Name:2403jam
Posted 25 August 2015 - 05:46 PM
Hi myss427 your right would love picture of the bit of the bracket that bolts to the fan if you got one just try to make car a good a9x replica thanks
#9 myss427
myss427
  • 1,636 posts
Posted 25 August 2015 - 10:49 PM
Have one on our madeira A9X but you would need to pull it a part to take a pic, Maybe RedA9X has one in his big collection of bits? Its pretty much just a ring thats about 1cm wide by 1.2mm thick that bolts to the fan motor and has 3 bolt holes. Have seen a few motors that only have 2 and they will not bolt up to the original bracket.
#10 2403jam
2403jam
  • 193 posts
  • Name:2403jam
Posted 26 August 2015 - 05:05 AM
Thanks myss427 going to torana fest hopefully i get to have a good look at a couple of a9x and take some pics thanks
