factory flexplate with a 355 ?
11 replies to this topic
#1 _stocaz78_
_stocaz78_
Posted 25 August 2015 - 12:57 PM
Hi all, will a standard holden flexplate be able to handle a 355 ?
Ive had alot of meshing problems that destroyed my aftermarket starter and chipped teeth of my aftermarket flexplate, ive bought a bosch starter now and need to buy a new flexplate.
I would go the magnum 308hd one, but i am paranoid that ill still have a problem with meshing so im thinking of getting an original holden one instead.
Any advice would be fantastic thanks
#2 IMORAL
IMORAL
    Bored
  • 2,567 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 25 August 2015 - 01:29 PM
I haven't had meshing problems but here is my standard flex plate behind my 355.
#3 _stocaz78_
_stocaz78_
Posted 25 August 2015 - 01:32 PM
Ok so that answers that question. What flexplate are you looking at ?
#4 TerrA LX
Posted 25 August 2015 - 01:40 PM
Meshing problems maybe alleviated by correctly shimming misaligned starters.
FWIW I have found aftermarket flex plates to be very noisy on engagement.
#5 IMORAL
IMORAL
    Bored
  • 2,567 posts
  • Name:Paul
Posted 25 August 2015 - 01:43 PM
I bought a heavy duty one but cannot for the life of me remember the brand sorry. If it comes to me I will let you know. It was just thicker from memory. It wasn't a TCI. Magnum rings a bell.http://www.magnumper...uemart&Itemid=2
I also changed the bolt size. Not sure if it needed it but I went to a 7/16 UNF chev bolt that had a longer shank so it acts as a dowel if that makes sense.
Just took the converter and plate to a machine shop to get them drilled so everything lined up perfect. The shank of the bolt is a neat fit in the hole. Held in with Loctite and tensioned up haven't had a problem since. (touch wood)
I think my original one may have had a bolt come loose but not sure as I always Loctite and tension them. I also don't know how old the flex plate was that I blew up.
Oh Forgot to add. Was running a brumby starter that I dint know the condition so it now has a VN V8 Bosch starter. Fits great and is physically smaller and is a reduction style....so I have been told.
I don't have any shims on the mounting but as TerrA LX mentioned I have read this sometimes has to be done.
Edited by IMORAL, 25 August 2015 - 01:53 PM.
#6 _stocaz78_
_stocaz78_
Posted 25 August 2015 - 01:52 PM
My starter was sitting so far from the flexplate it had to be shimmed on one side to bring the pinion closer to the flexplate which eventually caused to much pressure on the teeth and it snapped the top off the starter. The new bosch one is much better.
Ill give magnum a call.
Im not sure if my one is a magnum or not
#7 TerrA LX
Posted 25 August 2015 - 02:10 PM
Just one thing guys with you running these similar converters and HD flex plates, is the converter snugging into the back of the crank sufficiently to center it??
#8 yel327
  • 13,109 posts
Posted 25 August 2015 - 04:33 PM
Have a look at what the HSV 350ci Holden engine had for a flex plate. I think they may well be a stock VR-VS 5.0L 4L60E example which is the same as a HJ-HZ TH400 example (thicker than trimatic one). If that is what is being destroyed then ignore my post!
#9 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 25 August 2015 - 09:21 PM
Mine runs a standard Holden Trimatic flexplate, purchased new, been on 3 different engines, now behind an injected 363 (560ish HP), never had an issue, runs the standard old school non gear reduction starter, everything fits easy and always works.
Only standard Holden flexplate I've seen in the flesh as a failure had thrown a piece of the ring gear off in an Altered and it took a piece out of the powerglide bellhousing.
My previous engine used to be regularly turned to 8000RPM running 5.83 diff for the local 1/8 mile track. Standard size 3/8" UNF Bolts, torqued, and Loctite.
#10 _stocaz78_
_stocaz78_
Posted 26 August 2015 - 10:11 AM
Thanks for that ill do a bit more research.. im running a Turbo 700.
Is there a difference in size etc of a trimatic one or are they all the same size & fittment?
#11 yel327
  • 13,109 posts
Posted 26 August 2015 - 11:48 AM
AFAIK they are all the same. But i'd use a HJ-HZ TH400 or VN onwards 4L60/4L60E one as they appear to be identical except thicker.
#12 _stocaz78_
_stocaz78_
Posted 26 August 2015 - 11:58 AM
Thanks guys; )
