Best soundproofing underlay
10 replies to this topic
#1 _parsons5000_
_parsons5000_
Posted 07 September 2015 - 09:13 PM
Hey guys I'm looking at lowering noise inside cabin but I don't wanna glue anything down for rust free purposes what have people done ?
#2 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 08 September 2015 - 12:05 AM
The multilayer bitumen felt sound barrier stuff that trufit make works well if you don't want adhesive style stuff. It really cut the noise down in the old LX.
#3 _parsons5000_
_parsons5000_
Posted 08 September 2015 - 05:48 AM
thanks rexy , is it the same stuff as the all car carpets underfelt ? what thickness would trufit be ??
#4 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 08 September 2015 - 03:49 PM
It's kinda hard to photograph well. It's two layers of fabric backed felting with bitumin between, sticking them together. It squashes down ok and is easier to fit on a hot day after its left out on the driveway. I think trufit still have their factory out in Dandenong if you are passing that way.
Attached File  image.jpg   249.88K   4 downloads
Attached File  image.jpg   406.62K   3 downloads
#5 _Bomber Watson_
Posted 08 September 2015 - 03:57 PM
That stuff is 5000x more likely to cause rusting issues than something like dynamat.
#6 _LS1 Taxi_
_LS1 Taxi_
Posted 08 September 2015 - 04:01 PM
+1
#7 _parsons5000_
_parsons5000_
Posted 08 September 2015 - 04:42 PM
really why is that ? I'm just scared to stick something down that i can't pull up to check every 6-12 months
#8 _Bomber Watson_
Posted 08 September 2015 - 05:01 PM
Because it absorbs water.
#9 _LS1 Taxi_
_LS1 Taxi_
Posted 08 September 2015 - 05:45 PM
+1
No reason to check your inside floor pans for rust. POR15 your pans on both sides plus the dynamat/resomat is sticky as buggery. No way water or moisture is getting under that and rusting.
#10 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 08 September 2015 - 06:29 PM
Dunno. I had this in the car for years without a problem. I thought your best defence was keeping the car leak free?
The big pipes I had running under the floor certainly dried out any trace moisture!
#11 _Bomber Watson_
Posted 08 September 2015 - 06:51 PM
Absolutely rexy.
If you were proactive cleaning the floorpan up properly and keep leaks at bay, you wont have an issue.
Just that old mate said he didn't want anything sticky for rust reasons....
