How are you going with this Tony.. any luck
Was chatting to fella and has said he
he had the option of getting his seats & dr trim pressed but didnt have the time to wait.
Supertrim in Coburg is where he said can do it
i dont know how good they are or even seen
there work so cant recommend but def worth a look
Ps... is the material used for seats and dr
trim (roebuck) same as material used for roof lining as i see some on upholsterers sites
Cheers maz
I have purchased enough material to do the whole job.
I've been doing some research before deciding which way to go.
Originally the skins were pressed in one go. So the patern was nice and even etc.
It looks like there are a few people making the GTR ones this way, but no luck with the S 4door patern.
It's possible to have the lines individually "welded" into the material, but it would be a big job.
I have seen a sample of a single line where the patern was very similar.
It's probably not a big deal to make new rollers for the machine to match exactly, but I'm guessing it would be expensive and tough to maintain consistency.
At this stage I'm thinking I will just have the pattern reproduced using stitching.
I have also seen a 4 door with the GTR pattern, stiched. I have also considered doing this.
