Dipstick oil leak
_parsons5000_
Posted 27 September 2015 - 10:44 AM
_parsons5000_
Posted 27 September 2015 - 10:47 AM
Posted 27 September 2015 - 11:02 AM
Nice engine bay btw
Posted 27 September 2015 - 03:16 PM
Reinstall your dipstick tube with a tiny bit of black silicone to seal it up where it enters the oil pan.
If you have oil coming out the top of the tube you may have a blow by problem. You can leave the dipstick out and make a cap for the tube if need be.
_reefhog_
Posted 27 September 2015 - 03:42 PM
_parsons5000_
Posted 27 September 2015 - 04:14 PM
Posted 27 September 2015 - 06:50 PM
This is the ugly way to do it. I keep meaning to get something shinier but inertia is a killer.
_parsons5000_
Posted 27 September 2015 - 06:55 PM
Posted 27 September 2015 - 07:41 PM
I simply ran both my breather hoses into the air cleaner. The 355 ran high 11's all day without any breathing problems at all. No oil in the air cleaner eitherl. I tried the Tpiece as above but it kept blowing the dipstick out so it need both breathers venting in the air cleaner..No oil leaks either..
Edited by Redslur, 27 September 2015 - 07:42 PM.
_parsons5000_
Posted 27 September 2015 - 07:48 PM
Posted 27 September 2015 - 09:23 PM
_reefhog_
Posted 28 September 2015 - 09:09 AM
Posted 28 September 2015 - 07:33 PM
Red slur u got photos of what your running ?
No sorry. The engine is out now and I have fit a new one,. The breathers simply vent into the aircleaner and I did not have to run a PCV valve. Simple fix and very effective. Hope this helps.
_parsons5000_
Posted 29 September 2015 - 03:39 PM
_reefhog_
Posted 29 September 2015 - 07:01 PM
Posted 29 September 2015 - 07:18 PM
PCV only works at low RPM, doubt a correctly fitted PCV will fix shallow high RPM crank case breathing problems.
_parsons5000_
Posted 29 September 2015 - 07:53 PM
Manifold ... Wasn't sure if it is ok to run
Both pvc and brakes booster to the same outlet
Posted 29 September 2015 - 08:00 PM
NO. Do not run anything off the brake booster vac line.
