How to install gtr dash into my 73 lj
Posted 01 November 2015 - 05:52 PM
Posted 01 November 2015 - 06:20 PM
Hi Ben
You will need to find two of the clips pictured below. They slide into recesses on the dash panel right behind where the 2 bottom screws go through.
Bazza
Posted 01 November 2015 - 06:21 PM
#4 _v8fazz_
Posted 05 January 2016 - 09:00 PM
Hi guys.
Out of curiosity, would those 2 clips enable you to fit an LJ dash to an LC Torana, or do the clips not fit the LC so the 2 bottom holes on the LJ dash would just be empty and unsecured?
Are the clips available from anywhere like rare spares, etc?
Cheers,
Dave.
Posted 07 January 2016 - 07:54 AM
The two clips can be fitted to the LJ cluster to make it fit into an LC.
The LJ cluster will still have the two empty holes at the bottom, but you can put dummy screws with nuts in there.
The clips are simple enough to make them yourself.
#6 _Gunmetal LH_
Posted 08 January 2016 - 02:26 AM
I'm not familiar with where the screws go but this might help?
I'm a huge fan or nutserts/rivet-nuts. I cannot remember where I got them from? Either bursons or it might have even been bunnings/masters?
Like this-
Posted 08 January 2016 - 06:45 PM
Chris, these clips are for the LJ instrument cluster not the LC.
LC lower mounting brackets can be fitted to an LJ dash to install it into an LC and as you correctly say, the lower screw holes in the LJ instrument fascia will be empty so some dummy screws could be installed.
Posted 09 January 2016 - 12:13 PM
Sorry, when I said clips, I meant the two looped brackets that are on the bottom of the LC cluster.
Then again, you can just install the LJ clips and mount it correctly.
Edited by VDO, 09 January 2016 - 12:14 PM.
Posted 09 January 2016 - 01:17 PM
Prob easier to find original LC brackets than the clips for the LJ.
#10 _v8fazz_
Posted 09 January 2016 - 08:27 PM
Thanks guys
#11 _paul79479_
Posted 20 October 2017 - 07:09 PM
#12 _v8fazz_
Posted 25 October 2017 - 07:35 PM
Hi guys.
Just a question about doing the opposite of what was discussed above - If wanting to fit an LC GTR dash (complete with the 2 loop brackets at the rear) into an LJ is there something on the LJ dash panel for the looped retaining clips on the LC dash to attach to? Or do LJ Toranas not have this part / feature as the LJ dash's have retaining screws instead of the looped brackets?
