Initial castor and canber settings after K frame rebuild
13 replies to this topic
#1 slar
slar
  • 498 posts
  • Name:AL
Posted 22 November 2015 - 03:04 PM
Hi peoples......just wndering if any one could enlighten me on the initial set up of caster and camber shims after rebuilding an LX K frame.
Need to know how to measure for caster and camber to achieve roughly the correct shim thicknesses as a starting point so I can put the K frame and motor back in the car and be able to drive it to get a proper wheel alignment without it being dangerous or scrub the guts out of my tyres.
The old original shims are long gone so cant put back what was taken out...(didn't think about this when I stripped it years ago) so need a few dimensions to get it all roughly set up.
Al
#2 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 22 November 2015 - 03:35 PM
Just do it by eye. Grab some shims from the wreckers, local alignment bloke or Masters. You should be able to get it close enough.
#3 _76lxJAS_
_76lxJAS_
Posted 22 November 2015 - 08:18 PM
Use a spirit level for your camber.
Just put it on the the rims outer edges. U may need some little blocks to get it to sit nice and clear the tyres. I used a 600mm level for this. If you can get the wheel vertically level will be close enough to drive it.
Castor sux. But on ebay you can buy a magnet castor level that will get you pretty close to what is needed.
For memory you need to turn your wheels 20degrees to do this measurement. So then you will need some for of plate/board or floor markings to know u have turned them 20degrees.
There is a post somewhere here that explains castor measurement well. Just can't work out where to find it or link it from my phone.
#4 Bigfella237
  • 4,369 posts
Posted 22 November 2015 - 09:14 PM
Castor and camber even being a long way out may make it steer like crap but shouldn't scrub the tyres in a short drive to get an alignment.
What will scrub the tyres is toe, thankfully that's a lot easier to measure at home though.
Your starting point will depend on the components used, if you're running UC Torana UCAs and/or HQ stubs then I wouldn't put any shims in as you will likely have a reasonable amount of negative camber and positive castor already. Otherwise, as Jason said above, you can get it close with a spirit level but you must make sure the car is setup level on a level surface before you start, otherwise you have to compensate for the angle of the shed floor or driveway.
Once you've finished with the castor & camber and everything has been tightened up, then scribe a mark on the tread of each tyre, measure between these marks at the front then spin the tyres around half a turn and measure between the same marks from the rear and adjust the tie rods to suit, just aim for identical measurements (or zero toe) will be good enough to get you into the wheel alignment.
Edited by Bigfella237, 22 November 2015 - 09:19 PM.
#5 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 22 November 2015 - 10:30 PM
I did mine withe K frame off car and no springs installed.
I made a makeshift alignment caster / camber tool out of wood , fishing line and a protractor.
I set K frame to level position on bench, set lower arms or steering arms to horizontal position
and clamped tool to disc rotors.
For toe i clamped some long lengths of steel  on the discs and measured front and back.
Edited by fuzzypumper, 22 November 2015 - 10:30 PM.
#6 Peter UC
Peter UC
  • 765 posts
Posted 23 November 2015 - 11:44 AM
Look up 'string line wheel alignment' that should get you pretty close. There is a pretty good guide on Hotrod.com
#7 slar
slar
  • 498 posts
  • Name:AL
Posted 23 November 2015 - 07:55 PM
Ok thanks all....some interesting ways of getting it set up....i like the wooden jig...ingenious lol.
Will try some of these ideas and see how i go.
One question though....should the weight of the car be on the front end before setting it up or can it be done unloaded.
Al
#8 ls2lxhatch
  • 5,330 posts
Posted 23 November 2015 - 08:03 PM
Wheel alignment needs to be done at ride height.
#9 Bigfella237
  • 4,369 posts
Posted 23 November 2015 - 08:56 PM
Yep as ls2 says either with the weight of the car on some kind of skid-plate so the front wheels can move around freely, or do the alignment with the springs removed and the suspension fixed at the ride height?
I've seen many different ways to make the skid-plates, such as two flat sheets of just about anything rigid with a liberal layer of grease in between them, or two pieces of steel with ball bearings in between.
Just remember that if you elevate the front wheels to insert plates you must raise the rear wheels by the same amount to keep the car level.
#10 _grumpy 026_
_grumpy 026_
Posted 24 November 2015 - 11:36 AM
Al
I kept the old shims in separate labelled zip bags and put them back after rebuilding the K frame.
Put the car on a trailer and transported it to get the wheels aligned by a professional last week, so I know it's right.
G.
#11 rodomo
  • 17,997 posts
Posted 24 November 2015 - 09:48 PM
Al
G.
Agree................this would probably be the best way to start.
These tools will be what I will be using to ballpark mine. The rod is a telescopic tent pole.
#12 Bigfella237
  • 4,369 posts
Posted 25 November 2015 - 01:01 AM
Okay I have to ask Dammit, what are you planning to use the telescopic tent pole for (or maybe I don't wanna know)?
#13 _grumpy 026_
_grumpy 026_
Posted 25 November 2015 - 06:49 AM
Old school way of doing Toe in.
G.
#14 slar
slar
  • 498 posts
  • Name:AL
Posted 27 November 2015 - 09:37 PM
Ok thanks again fella's
Al
G.
Yeh I put all mine in zippies as well......did that with every part of the car but managed to lose the shims some how.......these are the only parts I cant find.....every other nut and bolt/part that came off the car is accounted for.
I will just follow the above advice and get it close then take it in to get done properly.........I'm just about to get the engine back in.... so need the k frame basically set up so I can move the car around and see how everything looks as I'm going.
Thanks for your advice
Al
