LC full brake upgrade
Posted 06 December 2015 - 05:43 PM
I've just joined but have been using the forum for a while now for info. Thanks, it's been very helpful so far!
I'm in the process of doing some work on my new LC 4 door.
I've just found that my master cylinder and booster both need to be rebuilt/replaced.
I already planned to do the hopper upgrade on the front and I have a set of VS commodore backing plates and handbrake assemblies for the rear. I planned to modify the backing plates to clear the shock and then rework axels for commodore stud pattern.
So I basically haven't purchased many parts and I'm up for a complete brake rebuild.
I should mention I'm considering a V8 upgrade at some stage. So booster clearance may be important.
Can anyone suggest a good combination that can be easily engineered and isn't too exotic?
Any advice would be appreciated.
Currently thinking:
Hopper front brake upgrade, commodore stud pattern.
VS commodore rear disks, modified backing plates and axels.
XU1 booster
Unsure on master cylinder? Rebuild or replace current?
#2 _71lc_1JZ_
Posted 07 December 2015 - 09:09 AM
easy and best way in Qld is to take complete system off donor car so use VS for it all booster and master that way all ADR work is done just a mod plate for new system.
That what my Mod platte man said for me todo with my brake conversion
Posted 07 December 2015 - 08:59 PM
Front brakes will be AU ford I believe. I don't think that should be an issue.
I've seen the post on using a VR dual diaphragm booster and master cylinder on LH/LX.
Anyone done this on LJ/LC?
#4 _Bomber Watson_
Posted 07 December 2015 - 09:30 PM
Stock master shoudl be fine.
XU1 booster will be fine, may cause clearance issues with a V8, but this can be easilly fixed in the following way.
Take a good hard look at yourself in the mirror. Put lipstick on and some mascara. Decide if you like the look or not. If you dont, stick with the six, no clearance issues with teh booster.
If you do like the look, go ahead and fit a v8, and sort your own frOcking clearance issues.
Posted 07 December 2015 - 10:29 PM
Mind you, maybe it's easier to do this than to change lines to metric at the ms?
There's the extra issue of the brake warning switch, do the newer ms have these as standard. May be a requirement if I upgrade?
I should highlight I've just upgraded the dash an installed the brake warning light just in case.
I'm not sure the silver fox would agree with you regarding your mirror trick, ha ha
Posted 11 December 2015 - 07:49 PM
I.e Upgrade the booster to a dual diaphragm VH324 and fit a new Master Cylinder.
The original master cylinder is a P6613.
I assume I can use this model again or maybe a P7210 as long as the push rod length is matched to the booster?
Then if I understand correctly I can remove the rear valve when I put the disks on the rear.
All the lines should have the right thread and bolt up.
So I'm just not sure which master cylinder is the best to use.
I'm also wondering if I should fit the later model distribution block with the switch. Probably not a bit deal, can do this anytime.
Any insight would be appreciated.
My old MS is full of mud, and the booster is full of fluid. Probably not worth much I guess?
Posted 11 December 2015 - 08:22 PM
I'd consider a few things,
Go with HQ stud pattern as there is a greater choice of wheels with a bit more dish that are in keeping with the older car, and if the axles are still 7/16" stud the commodore disk will fit, only need a hub ring to locate it correctly, or get the axles made to suit.
Change the front of the booster to an early commodore one, and then use the commodore master cylinder with the proportioning valve built in, cleaner, less plumbing, available to suit disk-drum or disk-disk, make a new push rod if the old one doesn't suit the new cylinder.
You could consider a 15/16" master rather than the typical 1" to help with peddle effort if you have to stick with the small booster for clearance issues.
You could also use an electric vac pump to supply the booster so that you again have enough assist using the small booster and the potential lack of vacume depending on how modified the engine ends up.
Posted 12 December 2015 - 08:24 AM
LC/LJ don't have a proportioning valve as I understand it. Just a distribution block.
Some have the pressure switch, but is just a block as its a 69 model and didn't have the warning light.
I was thinking about fitting one of these as part of all this.
I've seen a few people talking about fitting a VB commodore front half and booster.
Not sure if this can be done on the LC/LJ booster? Is the diameter the same?
There seems to be a millions options. The standard option seems to be the simplest approach for the same results.
Will be contacting HydroBoost and Hoppers again to confirm.
Might post some pics if I ever make a decision and do something, then someone else can have one more option to consider ha ha.
Posted 14 December 2015 - 08:20 PM
Posted 22 December 2015 - 09:20 PM
Posted 22 December 2015 - 09:30 PM
At this stage I think I'll mount the booster upside down to get away from this.
I have another check valve on the way that may work, but everything fits fine when the booster is inverted.
Posted 22 December 2015 - 09:33 PM
Posted 18 January 2016 - 10:14 PM
Brake kit is ordered from Hoppers
I'm waiting and waiting and waiting for a check valve to arrive before finally fitting the booster.
Never have much luck using Amazon.
Suspension has been cleaned and I'm working on the painting.
Need to fit new bump,stops and chasis mount bushes as well.
image.jpeg 183.56K 11 downloads
Posted 18 January 2016 - 10:35 PM
Fitting two tyres this week so I can get a good idea how much clearance I have
image.jpeg 141.7K 10 downloads
#15 _v8fazz_
Posted 24 January 2016 - 06:34 PM
Keen to see how the 17's go, what size tyres are you fitting?
Commodore stud pattern I assume?
Posted 24 January 2016 - 10:14 PM
I'm sticking with my original plan and going with 195/40 front and 205/40 rear
This picture shows the 195's. Don't have the 205's fitted yet.
The wheels are off a Hyundai IX35, 17x6.5 +51
I plan to eventualy fit 6" front and a 7" rear.
The rear wheels are easy sourced, the fronts will need to be custom.
I'm using adapters for the trial fit because I haven't upgraded the brakes yet.
I'll let you know the final offsetting-backspace I settle on once everything is fitted up properly.
I have just thrown everything together so I could make sure I was on the right track before fitting the next pair of tyres.
I'm going with a 5x4.5" stud pattern. Why?
More wheel choices, closer to the Torana stud pattern so the rear conversion will be easier, and I can run a standard F🤐rd front rotor. image.jpeg 127.16K 9 downloads
#17 _Bomber Watson_
Posted 25 January 2016 - 12:17 PM
Those 17" steelies will look frOcking awesome with some trim rings.
Posted 25 January 2016 - 02:24 PM
Yep, already Have a set in the mail.
Also looking at fitting the original centre cap.
Posted 07 February 2016 - 06:49 PM
Posted 07 February 2016 - 07:37 PM
Like the look..gtr caps were too small to bolt up to hq or commo pattern if memory serves correct.
Always wondered if gtr cntre caps could be modified/extended to fit...the metal on them looks thin & crappy though.
#21
Posted 07 February 2016 - 08:42 PM
I haven't spent much time on it yet. I don't want to modify the caps.
The PCD is a bit different but I'm thin inking I might be able to modify the wheel nuts and/or make an adapter.
#22
Posted 15 February 2016 - 06:57 PM
Put one on for a quick look
image.jpeg 289.54K 9 downloads
#23
Posted 20 February 2016 - 08:01 PM
#24 _Bomber Watson_
Posted 20 February 2016 - 08:11 PM
#25
Posted 20 February 2016 - 08:23 PM
image.jpeg 197.51K 9 downloads
