Interior lamp wires
10 replies to this topic
#1 Statler
  • 6,282 posts
Posted 11 December 2015 - 12:20 PM
Do the interior lamp wires run down the 'A' or 'B' pillars?
LH/X/UC
Edited by Statler, 11 December 2015 - 12:21 PM.
#2 hanra
  • 10,831 posts
Posted 11 December 2015 - 12:29 PM
A
#3 Statler
  • 6,282 posts
Posted 11 December 2015 - 12:34 PM
That's what i thought too.
I have shoved a scope up the A pillar & can't find the bastards!
On a plus note though, the inside of the pillars looks good. :)
#4 hanra
  • 10,831 posts
Posted 11 December 2015 - 12:40 PM
Are they up in the roof channel? Actually... Do you already have the roof lining fitted?
#5 Statler
  • 6,282 posts
Posted 11 December 2015 - 03:14 PM
Yep. Looks like i will have to peel back the roof lining & run some new wires.
Oh the joys! lol
#6 hanra
  • 10,831 posts
Posted 11 December 2015 - 03:33 PM
You got the windscreen in?
#7 Statler
  • 6,282 posts
Posted 12 December 2015 - 10:49 AM
Of course.
#8 hanra
  • 10,831 posts
Posted 12 December 2015 - 11:01 AM
Hmmmm. Gunna make things tricky.
#9 Bigfella237
  • 4,368 posts
Posted 12 December 2015 - 01:02 PM
Have a look at the under-dash wiring loom that you pulled out, the wire that runs up into the roof should be obvious, from memory I think it's a twin white/orange wire and it should be really long?
You shouldn't have to pull the windscreen, just un-glue the driver's side of the hoodlining and try to feed a long bit of tie wire down through the A-pillar, I've done this a couple of times but it's a prick of a job, it's like there's only a very small gap you have to get through?
Then tape a long section of the interior light wire to the tie wire and carefully pull it back through.
#10 Statler
  • 6,282 posts
Posted 12 December 2015 - 02:10 PM
That's the plan Andrew.
I have the wires at the lamp, but i've lost the other end.
Running a couple more wires thru isn't too difficult. I've poked antennae coax up thru that hole before. :)
#11 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 14 December 2015 - 11:23 PM
The interior lamp wires terminate on rear tail light loom plug which sits high up the kick panel.
