I don't post much on here, mostly just lurk a bit, but figured with the number of holden 6 tragics on here you lot may be interested in a head I just finished.
It started out as a stock 161/149 casting.
Got a hot tank, bead blast & crack test to make sure I had a good one.
Then:
Mill to equalise chamber depths as much as possible.
Spring seats recut parallel with face & to suit 1.5" dia valve springs.
Machined for screw in studs & guide plates.
Machined for bronze guides - guides are CHE to suit 7mm valve stems.
Seats cut for 1.69/1.42" valves - which are machined from 7mm stem blanks.
Then I cut out the intake head bolt bosses & machined it to take capscrews in the bottom of the ports & 3/4" UNF alloy grub screws in the top.
Ported the crap out of it & then made up the intake vanes to divide the intake ports & improve the velocity profile without being detrimental to flow V's fully open port.
Exhausts got small plates inserted to properly divide them.
I have shaped the chambers & sized the valves to maintain velocity into the cylinder for as long as possible (pressure recovery) to maximise cylinder fill.
Ports are sized for peak HP between 7000-7500rpm on a 208 cube engine.
As it sits the head will support up to 350hp on a very well built competition engine with triples, 12.5:1 comp (E85), tuned intake runner lengths & custom tuned headers.
Flow figures:
Intake
Lift - flow (cfm @ 28")
.1 - 52
.2 - 100
.3 - 140.5
.4 - 162
.5 - 185.5
.6 - 201
.7 - 206
.8 - 212
Exhaust
lift - flow
.1 - 49
.2 - 85
.3 - 110
.4 - 138
.5 - 155
.6 - 162
.7 - 171
.8 - 179
Average velocity on the 'active' side of the intake vane is around 210ft/s, on the secondary side it's around 135ft/s - so the vane is doing its job.
Flow with & without the vane varies only about 2cfm.
Edited by TK383, 16 December 2015 - 07:59 AM.
