I need to be able to provide the info to TMR for a project that I'm doing.
So need to be able to provide proof. Can have hear say.
Edited by lcxu105, 16 December 2015 - 09:09 PM.
Posted 16 December 2015 - 09:04 PM
Posted 16 December 2015 - 09:35 PM
I feel your pain here Dave, the only document that TMR might accept from you is a GMH service bulletin for the LH L34, which includes this page:
L34 Service Bulletin - Suspension.JPG 97.77K 31 downloads
Which says the L34 figures are:
14 x 6.00JJ rims with +0.25" (6.37mm) offset Standard Track Front: 57.89" (1470.4mm) (front hub-to-hub width 1483.1mm) Standard Track Rear: 56.82" (1443.2mm) (rear hub-to-hub width 1455.9mm) Rear = 1.07" (27.2mm) less than front
I've got a copy of the full thing here somewhere if you can't find it?
Apart from that, transport have their own spec sheets that they can look up and usually won't accept any figure except what those spec sheets say.
I've done a heap of calculations based on a measured LX SS diff width and the correct LX RTS SL/R & SS figures are:
13 x 5.5JJ rims with +1.25" (31.75mm) offset Standard Track Front: 55.3" (1405mm) (front hub-to-hub width 1468.5mm) Standard Track Rear: 54.4" (1382mm) (rear hub-to-hub width 1445.5mm) Rear = 0.9" (23mm) less than front
(Source: LX Torana owners manual)
Edited by Bigfella237, 16 December 2015 - 09:37 PM.
Posted 16 December 2015 - 09:41 PM
Posted 16 December 2015 - 09:57 PM
With the LX Hatch you'll be asking for the specs on the A9X, the front track should be the same as the L34 figures above (same suspension components, same rims) but the rear may be different because of the difference between brake drums and discs?
As you say, there are so many different sets of figures floating around it makes it hard to know what is correct.
Posted 16 December 2015 - 10:23 PM
DOH! What am I saying...
You're using the equivalent of both front and rear "axle assemblies" from the donor car, therefore the track measurements for a Torana are irrelevant.
From NCOP11_Section_ LS_Tyres_Suspension_Steering_V2_1Jan_2011 v3.pdf, page 47:
Track. Where non-original axle or suspension cross-member components are fitted,
the offset of the wheel in relation to the axle or hub assembly used must not be
increased by more than 12.5mm each side of the vehicle based on the specifications of
the axle components used. If an axle assembly is shortened then the track width limit
is taken as the axle manufacturers original track dimension, less the amount the
assembly has been narrowed, plus 25mm.
So your track figures will be based on the Adventra minus any amount you shorten the "axle assemblies".
If you want the official figures on the Adventra let me know, I should be able to dig them up on the Road Vehicle Descriptor System but I can't access that until 06:00am?
Posted 16 December 2015 - 11:05 PM
What model is the Adventra? If it's a VZ then I've found the RVDS sheet for it...
(see attached)
17 x 7.5JJ rims with +48mm offset
Wheel Track Front: 1617mm
Wheel Track Rear: 1623mm
So Front hub-to-hub width should be: 1713mm (230mm wider than the L34)
And Rear hub-to-hub width should be: 1719mm (263mm wider than the L34)
That's only 115mm wider each side, I reckon that should easily fit under a flare, the strut towers may be a different story though!
Posted 16 December 2015 - 11:36 PM
Just found this post which you may find of interest:
When the L34 was on the hoist I measured outside of flare to outside of flare:
Front 1770
Rear 1785
I thought 50mm off the outside flare measurement would be ok, 25mm each side. So outside to outside of wheel is 1735mm for the rear.
1735 - 450 = 1285 (450 is the total wheel width for both wheels)
1285 + 220 = 1505 (220 is the total back space for both wheels)
If your track is as before, then your outside of standard Adventra wheel to outside of standard wheel measurements should be (track plus 2x half the rim width):
Front: 1807.5mm
Rear: 1813.5mm
So, knowing that you can't reduce the track for the original axle components unless you narrow those components, you're gonna need some extra-wide flares, about 20mm per side I guess?
Posted 17 December 2015 - 05:36 AM
Posted 17 December 2015 - 11:57 AM
Posted 17 December 2015 - 03:00 PM
They want me to have the wheel track of the torana ,25mm max.
As quoted from the relevant section of the NCOP above (please look it up yourself to verify), that is simply incorrect.
I'd take a copy of the NCOP in to your engineer and point that out, if he or she still insists on using the Torana figures then they can't be very good at what they do, so it's time to find a new engineer!
The whole point of the wheel track restriction is to maintain the distribution of load across the wheel bearings as designed by the manufacturer. The offset of the rim determines how much of the vehicle's corner weight is supported by each bearing:
70221TimkenHubC_00000028548.jpg 18.9K 4 downloads
If you move the wheel offset, thereby changing the wheel track measurement, you move the load:
what_is_wheel_offset-450x261.jpg 30.48K 7 downloads
Which can cause premature (and potentially catastrophic) bearing failure. This problem is compounded by the fulcrum effect, where the further you move off centre, the more leverage the load has.
This usually applies to Torana owners bolting on wide rims with a huge negative offset (deep dish), but is equally relevant in your situation if you were to move the rims inward to meet the Torana track specs.
I believe the Adventra has a uni-bearing setup on all four corners too (one big single bearing on each wheel instead of two) so I'd think the load centre thing would be even more critical?
I agree 100% with the NCOP, and disagree with your engineer, the track specs must be based on the axle components used, not whatever bodyshell happens to cover them.
Posted 17 December 2015 - 08:22 PM
Posted 17 December 2015 - 08:25 PM
Posted 17 December 2015 - 09:06 PM
If you read how it is written than the moment you narrow the diff you have to use the original cars track +25mm max.
Not sure where you got that from?
The "original track dimension" is of the "axle manufacturer", not the car manufacturer, (in this case you have to pretend that the Adventra "manufacturer" is different from the Torana "manufacturer").
Yes I know the wording of this document leaves a LOT to be desired, in my opinion the NCOP should NOT even mention track width, it should deal only with rim offset as it relates to wheel bearing load, but let's not get started on the syntax within these documents or we'll be here for a week!
What that's saying is, if you narrow the "axle" 200mm, you must also deduct that 200mm from the axle manufacturer's original track measurement, which means the original offset wheels that were fitted to that axle will still be correct.
As I said earlier, the whole point is to maintain an even load across the wheel bearings as was designed by the manufacturer. You cannot possibly expect the manufacturer of a circa 1977 Torana to know what wheel bearing loads a 1995 AWD Commodore should have?
I don't know how else to explain it, your engineer should surely know all this already?
The only requirement for the bodywork is that...
the wheels or tyres do not protrude beyond the bodywork of the vehicle when viewed
from above;
...and obviously that the overall width of the vehicle does not exceed 2.5 metres!
Posted 21 December 2015 - 07:51 PM
Posted 21 December 2015 - 08:19 PM
As far as I can see, your engineer just doesn't grasp the fundamental principle behind maintaining 'close to factory' load distribution across the wheel bearings?
As I already mentioned, it seems he or she would be happy with massive positive offset rims just because they satisfy the Torana track measurements, never mind the fact that the wheel bearings, drive axles and spindles are all now under extreme load?
And how about the huge negative scrub radius? I really have my doubts that you will be able to shorten all the driveshafts and move all the suspension components inboard far enough to obtain the Torana track measurements and still have any kind of acceptable suspension geometry or workable CV joint angles?
If I were you, I'd be sitting down with other engineers and getting their judgement.
But anyway, that's my opinion, I've given it and wish you the best of luck!
Posted 21 December 2015 - 08:34 PM
Posted 19 August 2017 - 12:38 PM
Posted 19 August 2017 - 11:31 PM
At the risk of starting yet another argument on the subject...
A standard (non-A9X) LX front-end should be roughly 1468mm from one wheel bolt-up-face (BUF) to the other, according to my notes.
That equals a standard front track measurement of 55.3" (1405mm) when using a 13x5.5" rim with a +1.25" (+31.75mm) offset:
1405 + (2 x 31.75) = 1468.5mm
Posted 20 August 2017 - 12:49 PM
Posted 20 August 2017 - 12:52 PM
Posted 20 August 2017 - 10:50 PM
A9X wheel track figures are all over the place depending on the source.
A9X (version 1 - Source: "45 Years of Holden", Terry Bebbington and Michael Malik, 1994, pages 93 & 96):
Track Front: 57.2" (1452.88mm)
Track Rear: 56.1" (1424.94mm)
A9X (version 2 - Source: "60 Years of Holden", Terry Bebbington, page 338 - Basically the same figures as L34):
Track Front: 57.9" (1470.7mm)
A9X (version 3 - Source: Just Holdens Toranas Collectors Series. A9X Edition, page 23):
Track Front: 59.5" (1511.3mm)
Track Rear: 57.1" (1450.3mm)
There is a GMH Service Bulletin floating around for the earlier L34, which uses the same stub axle/hub components as the A9X just with different control arms and wheel alignment specs, and it says L34 is:
I myself would trust that the GMH Service Bulletin is correct, all the other figures were likely obtained by two monkeys in a parking lot with a tape measure, so who knows?
Posted 20 August 2017 - 11:38 PM
Edited by Shtstr, 20 August 2017 - 11:40 PM.
Posted 21 August 2017 - 02:37 AM
Yeah I think you're in murky waters, you really need to find out what track figure your engineer will accept before doing any measuring or math. I really can't stress that enough!
Engineers and rego authorities typically have their own set of data, which is often different from what everybody else will tell you, and they won't even hear of outside sources that say differently.
Also, some engineers will accept that an A9X was part of the same LX Torana model, some say that if your car was an "SL" then that's what figures should be used.
To further muddy the waters, some engineers will argue that the A9X came out in 1977 only so if your car is a '76 you can't use the A9X figures.
And then any real engineers will treat all those figures as a guideline and actually sign off on the engineering itself, as should be done!
It really sucks that the so-called "regulations" leave so much to individual interpretation but what can you do.
Edited by Bigfella237, 21 August 2017 - 02:38 AM.
Posted 21 August 2017 - 08:14 AM
Posted 21 August 2017 - 10:28 AM
When I got mine engineered years ago, had to get a letter from Holden stating the track for A9X, it came back from them at 1510mm. Or that could have been including the additional allowed 25mm?
Edited by myss427, 21 August 2017 - 10:30 AM.
