auto transmission
12 replies to this topic
#1 _rawdog_
_rawdog_
Posted 09 January 2016 - 06:32 PM
I have a street regularly driven LC with a worked 202 and 3.55 diff gearing. Currently has a trimatic. Great to drive around town but revs a bit hard at 100km. Considering replacing the transmission. Want to remain automatic. Looking for some info as to what is a good tough transmission that won't compromise bottom end power but will allow better RPM on the highway? Or can the trimatic be modified?
#2 yel327
  • 13,072 posts
Posted 09 January 2016 - 06:59 PM
Trimatic will do all you ask, just change the diff centre to 3.08, or get taller tyres. And converter to suit the whole lot.
#3 S pack
  • 15,538 posts
Posted 09 January 2016 - 11:31 PM
Agree, any transmission that isn't overdriven in top gear is not going to be an improvement on the Trimatic.
#4 _Muzzy_
_Muzzy_
Posted 10 January 2016 - 12:15 PM
Trimatic was often married up to 2.78:1 with 13" wheels when fitted with 202
#5 S pack
  • 15,538 posts
Posted 10 January 2016 - 02:52 PM
Trimatic with 2.78:1 ratio diff was a std combo for 138, 161 and 173 engines also.
#6 _Muzzy_
_Muzzy_
Posted 10 January 2016 - 04:27 PM
Thanks, I knew this, the original question was about a 202 hence my answer
#7 S pack
  • 15,538 posts
Posted 10 January 2016 - 04:45 PM
No probs Brian, just mentioned it for anyone that may not be aware the 2.78:1 diff was the std fitment behind the Trimatic.
Edited by S pack, 10 January 2016 - 04:46 PM.
#8 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 10 January 2016 - 06:12 PM
Gee that's gonna kill your takeoff if you go 2.78 or 3.08.
Maybe some sort of overdrive ala gear vendor or similar might be available. Best of both worlds.
#9 yel327
  • 13,072 posts
Posted 10 January 2016 - 06:55 PM
A lot of money to spend to do simply what a taller diff will do! Even dropping back to a 3.36 will drop your revs by over 5%. 3.08 by over 15%.
I think there are kits out there to fit VN-VP V6 4L60 boxes, but again a lot of expense. A 202 LC with 13" rims should be fine with a 3.08:1 rear axle, especially an auto. Get a converter with a bit more stall in it if takeoff is too much of a concern.
#10 Redslur
Redslur
    Has been Torana owner
  • 3,531 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 10 January 2016 - 07:04 PM
Go for the 3:36 as suggested above. Much better all round ratio for around town and on the highway. A T700 will suck too much out of a 202 IMHO.
#11 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 10 January 2016 - 07:38 PM
I have an LC with a trimaric, 3000 stall, 336 diff and 13s. It sits on 2800 revs at 65 mile per hour
Cheers DazM
#12 D-Train
D-Train
  • 171 posts
  • Name:Dion
  • Car:LC SL
Posted 31 May 2017 - 10:50 PM
Dml, I've got a simikiar setup and find it a dog on take off but my converter is a 1500.
#13 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
Posted 01 June 2017 - 07:28 PM
Hi Dion. To help you out I have a 186s with a Wade 373 grind cam ( HX XU1 cam ). I have a VH Commodore electronic ignition that is set at 16 deg adv. "The cam kicks in at 2800 rpm so that is why I run a dominator 3000 stall. Probably a 2800 stall is ideal but are too expensive.
Off the line no problems. I have a stage 3 yella terra and triple 150CD and bored to a 192. I only had 3 runs at Calder and all were 16.2 flat.
Cheers DazM
