too easy mate just let us know wen your coming down I'm only home every 4 weeks atm I'm sure we will catch up one time..
#51 _Drag lc_
Posted 14 April 2016 - 08:50 PM
#52
Posted 29 April 2016 - 08:38 PM
She did a dyno run yesterday with fuel dramas(running lean at the top end) tuning issue we assume , result was 197hp atw (147kw) 445nm @ 5400rpm . A/r was to high past that rpm , I'm running 0a7 atm but may have to try some others.. Rev limiter is set at 7000 but we didn't make it there, Mabe next time
#53
Posted 29 April 2016 - 08:47 PM
#54 _LCGTR70_
Posted 30 April 2016 - 04:11 PM
Good power for a 6
#55
Posted 30 April 2016 - 07:59 PM
#56
Posted 01 May 2016 - 09:56 AM
Yeah mate it's not bad, I'm hoping for 220+ hp atw, the engine has only just clicked over 1300kms , I'd say there's a long road ahead haha
What are the engine specs mate? Cam specs?
Lovely setup mate!
#57
Posted 01 May 2016 - 03:24 PM
#58
Posted 01 May 2016 - 09:38 PM
#59
Posted 08 May 2016 - 08:59 AM
Hey seen your car on Friday morning in rocky, parked near the pie van on Gladstone road with a couple of EH utes. That colour jumps out, looks great. Couldn't stop and chat was on a quick trip up and back.
#60
Posted 11 May 2016 - 07:21 PM
#61
Posted 01 January 2017 - 07:50 PM
#62
Posted 02 January 2017 - 12:49 AM
#63 _Drag lc_
Posted 02 January 2017 - 08:11 AM
did you get it sorted mate?
#64
Posted 03 January 2017 - 08:28 AM
In 5k kms it's done
3coils
3 dizzy caps
Ignition box broke 3 times now
This drive it lasted 1 hr b4 it shut down , it's becoming very repetitive sending the kit back to him every 2 wks
#65 _Agent 34_
Posted 03 January 2017 - 02:13 PM
not major but run two set ups on both cars.
we took the so called " booster " of the race car as it was doing weird stuff and was not doing the boosting it claimed.
both of these are the old school bosch.
get a bosch - send it to scorcher ignition with the following;
comp
cam specs
head details
and what you want it for.
then just present 12 #olts to the coil and you will feel a lot better. just keep it simple on these engines.
the dizzy rebuilds and ser#ices are cheap
Edited by Agent 34, 03 January 2017 - 02:16 PM.
#66
Posted 04 January 2017 - 01:06 PM
Heard of few holden v8's swap out their ice setups to go crane or even make do with locked dissy/hei coil after they gave up chasing issues.
#67
Posted 04 January 2017 - 06:55 PM
+1 for scorcher...
I had them rebuild my HEI. A great job and not much money really. I was going to do it myself but couldnt get the parts like a new chopper plate etc so just sent it to scorcher.
I agree that these engines do not really need much fancy stuff (even though I run it all).
Good luck mate, regards
#68
Posted 07 January 2017 - 06:31 AM
#69
Posted 02 October 2017 - 04:43 PM
I've decided on the mikuni Hsr carbs should have them fitted within afew wks than back on the dyno for tuning , than power run.. Should mate for a interesting comparison
Edited by Niz, 02 October 2017 - 04:52 PM.
#70 _duggan208_
Posted 02 October 2017 - 11:40 PM
Yes, that will be interesting, did you get the 50mm?
Regards
#71
Posted 03 October 2017 - 12:32 AM
#72 _duggan208_
Posted 04 October 2017 - 11:43 PM
Are the throttle linkages similar to the SUs?
Regards
#73
Posted 06 October 2017 - 11:44 AM
On my set the throttle shafts have been extended and therefore are all connected, with shaft clamps, with a 8mm(from memory) shaft. The cable attachment bracket attaches to the shaft. I made a throttle cable sheath mounting bracket that bolts onto the manifold
Super simple if you have a cable throttle.
#75
Posted 09 October 2017 - 10:09 PM
Edited by madtoranajzedded, 09 October 2017 - 10:10 PM.
