What is the general consensus regarding the best headers/extractors for the 308 on an LH? There are so many different companies who make them OTS, but with all things there is the good and the cr@p ....
Headers/Extractors question
#1 _ozhummer_
Posted 11 February 2016 - 08:56 AM
Posted 11 February 2016 - 09:27 AM
Personally
I use Pacemakers
If you have a hydraulic slave cylinder you have to be careful that the extractors clear it.
I think Pacemaker and Genie are the most popular.
s
Posted 11 February 2016 - 09:58 AM
I have Pacemakers but only test fitted at present. Only potential issue I see is with the starter motor but I don't intend on using original so will source one that fits. Cheers Ron
Posted 11 February 2016 - 11:11 AM
Pacemaker for sure. Have used Genie too and no complaints there either..Pacemaker clear hydraulics ok.
Posted 11 February 2016 - 11:56 AM
Pretty much everything I've ever had on an early he added car has fit fine. Plenty of room around starter.
The 1.75 primary Tri y pipes for VN heads from CAE fit very well.
Posted 11 February 2016 - 12:57 PM
What are the HM headers L34 type like performance vise compared to the pacemaker or genie, or are they all much of muchness?
#8 _74LH_
Posted 13 February 2016 - 03:31 PM
Posted 16 February 2016 - 06:16 PM
Posted 16 February 2016 - 06:45 PM
I've gone with pacemaker on a 304.
Isn't a 304 the same block as a 308 but with a different stroke? They do have the numbers 308 cast into the block right?
s
Posted 16 February 2016 - 07:39 PM
Perhaps he is referring to VN headed 304??
Posted 16 February 2016 - 07:40 PM
Posted 16 February 2016 - 07:43 PM
#14 _Doggies73_
Posted 05 May 2018 - 02:29 PM
Ok, so which Headers/ Extractors to use with hydraulic clutch?
Early model 308, M21 with hydraulic clutch.
Posted 05 May 2018 - 09:58 PM
I had tri-Y pacemakers on my LH 253 with M21 and hydraulic clutch setup.
It all fit OK, albeit tight.
