221 stroker with 3xcd 175s , recommended Perth engine tuner
186 with 221 crank Stroker
16 replies to this topic
#1 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 28 February 2016 - 03:38 PM
Hi members,
Just after some recommendations on who would be recommended to tune my motor
,here in Perth ,
She's a 186 running a 221 ford crank , with factory xu1 cd175s
thanks Warren
#2 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 10 March 2016 - 10:52 AM
Hi all , thanks for the PM s I ended up going with Ray Geneve , in Osbourne park with a dyno , trading as Geneve Automotives , see you all at the Brookton motor show on the 19th March
#3 Shiney005
  • 9,720 posts
Posted 10 March 2016 - 12:19 PM
Did you build that motor Warren or did you buy it? I only ask because my brother sold one with the same crank and carbs years ago. I remember it being quite torquey for a six, but it didn't like revving beyond about 5000. His was built by Wayne Bell if I remember correctly.
Edited by Shiney005, 10 March 2016 - 12:21 PM.
#4 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 09 April 2016 - 05:01 PM
No I didn't build it, I got it about 5 years ago as it came with a project I bought at the time, just behind Perth airport, it was complete except for sump, , had to change spigot bush as it must of been running a different box to the all Aussie,, other than that it's sweet, tricky rocker cover as the height of rockers, studs and push rods was quite high, and yes she. Is torquey , and has now got about 1000 kms on her since the motor went back in to the LJ
I was lead to believe it came from a ex speedway car
#5 Potta
Posted 09 April 2016 - 11:23 PM
Sounds bloody good too  :spoton:
#6 _Skapinad_
_Skapinad_
Posted 10 April 2016 - 06:13 AM
Video of it running please ;)
#7 Shiney005
  • 9,720 posts
Posted 11 April 2016 - 12:28 PM
It could be the same one. My brother's was running a Supra 5 speed. If I remember correctly it had 1.65 Yella Terra rockers back in the day. He hit a roo in it and destroyed all the panels forward of the windscreen. He put a V8 in it when it was rebuilt.
#8 dattoman
Posted 11 April 2016 - 08:57 PM
When I was a younger lad there was a guy (anthony) that had a 235 in his EJ
Sounded great for a 6
No idea what happened to it
#9 Ice
  • 15,213 posts
Posted 11 April 2016 - 08:58 PM
Anyway bar all the BS whats it rev to
#10 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 15 November 2019 - 07:19 PM
Same motor , different rocker cover,
Had to do the exhaust gasket after the 550 klm run to Perth, Two Rocks, motorplex and back to Busso,
So I did the 2 flange gaskets as well,
Running 205/13/60
With the 3.36 fine spline I was raving to 55000 with the strocker thought that was pretty good,
Very quick down low,
For the Torana west weekend I swapped the diff to a 2.78 LSD
Still revs stron down low and now it's comfortable on 110 klm pulling 2800 rpm...
#11 yel327
  • 13,720 posts
Posted 15 November 2019 - 07:40 PM
Gives you an idea why Hemi 265’s with triple carbs go so well. Cubic inches is always the answer! I’ve always wanted to see a 6 lover work a 292 Chev 6 like the way Holden 6’s get worked. There are a fair few HK-HJ coming back from South Africa with 250ci versions of the same engine, many already have TH350 boxes. Some are well priced too.
Here is one but a Powerglide. Work this with triples!
https://www.carsales...=SSE-AD-5531164
Edited by yel327, 15 November 2019 - 07:45 PM.
#12 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 16 November 2019 - 04:46 PM
I don't know if the parts are available but a 292 chev with triple Webers and a head that's the equivalent of the jzed head would be an interesting project.
#13 yel327
  • 13,720 posts
Posted 16 November 2019 - 05:09 PM
I don’t think you’d need to go to that expense. One of these would do and make serious power compared to the smaller Holden 6.
https://www.ebay.com...kcAAOSwItddxA52
Some good info here. Love the welded together SBC heads!
https://www.cranksha...hevy_250_engine
Back to the original thread.......
#14 _macdou_
_macdou_
Posted 17 November 2019 - 07:35 AM
Yes and triple 2” SU would certainly make it move and simple to setup. :-)
Edited by macdou, 17 November 2019 - 07:36 AM.
#15 8BALL
8BALL
  • 187 posts
  • Name:..
  • Car:yep
Posted 19 November 2019 - 10:54 PM
Jump on youtube and check out the Chevrolet Opalas in Brazil drag scene. Most run a 250ci 6.
Some make close to 2000hp apparently.
#16 yel327
  • 13,720 posts
Posted 20 November 2019 - 06:59 AM
Been reading about them on US sites. Looks like a 60 thou overbore to 5litres, lump port head, good balance and a very expensive damper are the go. Combine with a 4BBL manifold and Holley sniper plus hyperspark and extractors and it’d probably go as hard as most 5 litre V8’s with mild mods.
#17 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 13 January 2020 - 03:00 PM
Spark plugs for the strocker,
Best so far has been NGK BP6FS
