i know how you feel
i think i removed a barrow load of bog from mine
but like yours now being done properly
keep up the good work
cheers bat
Posted 16 August 2018 - 10:58 AM
i know how you feel
cheers bat
Posted 18 September 2018 - 09:45 PM
Slowly cutting bits of rust out and repairing, Here are photos of chassis rail repairs I have done. Not perfect but am going to spray body deadener under car which will hopefully hide any imperfections, blemishes, cheers paul.
Posted 18 September 2018 - 10:33 PM
Posted 28 September 2018 - 08:38 PM
Started paint stripping ready for sandblasting and etch prime. Glad I decided to go back to bare metal as I couldn't believe the amount of bog under paint on the guards, doors bonnet and boot are pretty good. I/m going to bite the bullet and splash out for a new set of guards as these ones are too far gone and it will be more cost (and time) effective to get new ones, Paul
Posted 21 October 2018 - 09:00 PM
Have taken some long service leave to get stuck into project and got following jobs done:
more photos to follow as can only post a few photos at a time,
Paul
Posted 21 October 2018 - 09:04 PM
Photos of underside, next job to paint strip shell and have cleaned up, primed by sand blaster.
Posted 21 October 2018 - 11:50 PM
Posted 22 October 2018 - 03:16 AM
Gene, I'm using one that came with car when I brought it and pretty sure is LJ as ignition is on steering column, whereas LC is on dash, is that correct? Will it make a difference to which one I use? thanks paul
Posted 22 October 2018 - 07:43 AM
Posted 22 October 2018 - 09:42 AM
Good point, havn't got that far yet and hadn't thought of that, will cross that bridge when I get to it, but thanks for picking that up, paul
Posted 11 November 2018 - 11:43 AM
Photos of hanging panels back from sandblaster in 2 pack epoxy, shell off to sandblaster and how it looks after, warts and all. Luckily no surprises around windscreens, rain gutters ect but still al lot of work to do before ready to paint. I thought I have turned the corner for the home straight but maybe not, Thanks to Jeff from this forum for lend of his trolley which makes life a lot easier.
Posted 27 February 2019 - 09:27 PM
Havn't updated thread for a while but have been busy working on project. Filled in speaker holes, had a panel beater mate give me a hand putting car back together and we discovered rhs chassis rail was out about 10mm. With a few gentle "taps" now all sorted, wasn't happy with how I fitted drivers side sill so we fitted a new one, in the process realised inside "A" pillar was cracked near the floor pan so repaired that. Fitted a new inner guard caus the old one was #@$%^&. Welded new guards/nose cone in and made sure all the doors, bonnet, headlights/grill fit. Repaired drip rail on drivers side. Next he needs to fix up wheel arch pass side then start body filler, 2K high build primer. Hope to have it painted din a few weeks - Paul.
Posted 27 February 2019 - 09:29 PM
I forgot to say all under the watchful eye of quality control and oh & s officer "Rosie"
Posted 28 February 2019 - 06:05 AM
It's looking good.
Well done
Posted 13 March 2019 - 05:20 PM
Posted 25 April 2019 - 02:33 PM
Hi Build primer has been done and dry sanded, missus has helped do the wet blocking back, what a trooper! should be ready for old mate from car club to paint in a few weeks, paul
Posted 25 April 2019 - 03:08 PM
Posted 25 April 2019 - 04:03 PM
exactly Gene, cant wait to finally see some glazier white on the car,
Posted 25 April 2019 - 04:29 PM
Posted 25 April 2019 - 08:47 PM
Awesome work so far mate
I'll be keeping an eye on this thread for motivation to keep going with mine
Posted 29 April 2019 - 08:09 PM
Looking awesome Paul - it's a nice feeling once it's all one color even if it's undercoat.... keep up the good work!
Posted 29 April 2019 - 09:19 PM
Thanks guys, appreciate the encouragement, jeff the trolley you lent me has been invaluable, i'll make sure you get it back when I have finished painting.
Posted 03 May 2019 - 08:45 PM
We painted the white today, gloss not too bad off the gun but as its acrylic it will be wet sanded, buffed and polished at a later date, next stage will be blackouts, tossing up whether to put on the rear spoiler or not.
Posted 04 May 2019 - 08:58 AM
Looks good how many coats you lay,, well done
Cheers gong
Posted 04 May 2019 - 09:40 AM
6 coats as 2 will probably be sanded off in wet sanding, thanks john
