1/4 window assembly
16 replies to this topic
#1 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:2005 CV8 Monaro
Posted 20 March 2016 - 06:05 PM
Me again.
Would you think that the washer in the pic below would be number 42 in the part list? Holden call it a stop in the listing.
Attached File  image.jpeg   116.23K   14 downloads
#2 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 20 March 2016 - 06:11 PM
Yes
#3 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 March 2016 - 06:33 PM
Cheers Paul
#4 S pack
  • 15,538 posts
Yes
+1
#5 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 20 March 2016 - 07:07 PM
Rare spares has a clip on you tube on how to install the quarter vent window
#6 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 March 2016 - 07:53 PM
I thought that was only the rubber. I'll have another look.
#7 S pack
  • 15,538 posts
Posted 20 March 2016 - 08:51 PM
Had a look at the LC/LJ 1/4 vent window vid in Rare Spares Shed Talk and yeah it covers the installation of the rubber seal.
Personally I wouldn't remove the glass from the pivots unless absolutely necessary as the glass is glued to the pivots during manufacture.
Simply unscrew the pivot pin from the upper pivot. Remove the retaining nut, washers and spring from the lower pivot.
Next remove the two screws holding the lower pivot bridge bracket, remove the bracket and remove the pivot rotation stop washer and washer.
Next with the 1/4 glass in the open position maneuver the upper pivot from the seal and withdraw the glass (with pivots attached) from the frame and seal.
Remove and replace the seal and assemble in the reverse order and tension up the lower pivot so the breeze won't blow the window shut at 120mph. :)
Edited by S pack, 20 March 2016 - 08:52 PM.
#8 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 March 2016 - 09:03 PM
Fitting new glass Dave, so sorta need to remove the pivots. I bought some used extras, just in case, & interestingly the top pivots are a different size to mine
#9 S pack
  • 15,538 posts
Posted 20 March 2016 - 09:28 PM
Yeah that is sort of necessary then hey Tony.  I'd be interested to see some pics of those different size top pivots compared to your originals.
#10 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 March 2016 - 10:15 PM
I'll get some measurements for ya
#11 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 21 March 2016 - 04:48 AM
Find someone with midget hands too. Undoing the nut and removing = not so bad. Getting the washers etc back on and doing nut up = sheer frustration!
#12 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 21 March 2016 - 08:47 AM
Pretty easy on the bench!
#13 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
Posted 21 March 2016 - 03:43 PM
Your not wrong about that! I did mine with frames still in the fully assembled doors and it was nothing short of horrific let me tell you....
#14 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 22 March 2016 - 07:08 PM
On closer inspection Dave, the used pivot I had bought has been mushroomed somehow...
#15 _SableMet7/73_
_SableMet7/73_
Posted 11 January 2018 - 11:28 PM
Hi, can someone post a pic of the correct position of the pivot stop washer?
Mine were positioned so's the glass opened up to & beyond 90 degrees with the washer not contacting the bracket at all.
So I tried it all 4 ways & when it was stopping against the bracket the glass only opened 50 to 55mm, measured at the lower rear corner.
Is that right?
I watched Rare's Youtube vid & positioned Rare's way but dosn't stop on the bracket, back to where I started.
Also what's the consensis regarding the current Rare's seals? I saw Bombers vid so definately will steer clear of Betta.
The ones fitted don't fit my frame well & should replace them.
Any advice appreciated.
Thanks.
#16 S pack
  • 15,538 posts
Posted 12 January 2018 - 09:33 AM
Mine were positioned so's the glass opened up to & beyond 90 degrees with the washer not contacting the bracket at all.  Correct. The 1/4 window is designed so the glass opens past 90 deg.
Also what's the consensis regarding the current Rare's seals? I saw Bombers vid so definately will steer clear of Betta. IMO the Rares 1/4 window seal is the best repro on the market ATM.
Thanks.
Edited by S pack, 12 January 2018 - 09:34 AM.
#17 _SableMet7/73_
_SableMet7/73_
Posted 14 January 2018 - 06:59 PM
Thanks Dave.
