operating tempreture
18 replies to this topic
#1 _ljxu1torana_
_ljxu1torana_
Posted 02 May 2016 - 09:54 PM
what is the operating tempreture in farenheit
#2 rodomo
  • 17,997 posts
Posted 02 May 2016 - 10:01 PM
More info? What car?
#3 _Bomber Watson_
Posted 02 May 2016 - 10:11 PM
Anywhere under 900 deg f is fine.
#4 _ljxu1torana_
_ljxu1torana_
Posted 02 May 2016 - 10:22 PM
in a lj torana.i have fitted a hq v8 3 row with a comet push style fan,when sitting at the traffic lights it sits on 190 farenheit,i use just water only and with the guts of the tempreture sender been cut out,
#5 rodomo
  • 17,997 posts
Posted 02 May 2016 - 10:23 PM
I think you'd better have another look at boiling temperatures Boomer?
#6 S pack
  • 15,522 posts
Posted 02 May 2016 - 10:27 PM
What is a comet push type fan?
Do you mean the guts of the thermostat have been removed?
My LJ quickly goes up to 190F when sitting idling. Without the thermo fan it would be heading over 200F in no time
#7 _ljxu1torana_
_ljxu1torana_
Posted 02 May 2016 - 10:29 PM
yes thermostat i will have a look at the brand of the fan.i might have the wrong name
#8 S pack
  • 15,522 posts
Posted 02 May 2016 - 10:32 PM
Is it an engine mounted fan or a thermofan mounted in front of the radiator?
An engine mounted fan or any thermo fan mounted on the engine side of the radiator must draw or pull the air through the radiator.
All you are doing by removing the guts of the thermostat is extending the period of time the engine takes to get up to running temp and probably causing excessive wear to the engine. Most engine wear occurs when the engine is cold.
Edited by S pack, 02 May 2016 - 10:35 PM.
#9 _ljxu1torana_
_ljxu1torana_
Posted 02 May 2016 - 10:35 PM
its a comex brand it sits in front of the radiator in the middle,the fan is wired into the accecories,should i use glycol,its a turbo 186.
#10 _ljxu1torana_
_ljxu1torana_
Posted 02 May 2016 - 10:40 PM
the comex fan is in air flow 1240 cfm fan flow=puller fan type=universal
#11 S pack
  • 15,522 posts
Posted 02 May 2016 - 11:02 PM
So let me get this straight.
You have the thermo fan mounted in front of the radiator between the radiator and the grille, that is to say not between the engine and the radiator?
The fan is a puller type which means you are pulling the hot air from the engine bay back through the radiator and expelling it out through the grille?
#12 _mervx_
_mervx_
Posted 03 May 2016 - 05:03 PM
Its the same temperature as you asked and were told on other forums. Did you not believe Adam Hills when he told you? thanks
#13 VDO
VDO
  • 187 posts
  • Name:Chris Curtis
Posted 04 May 2016 - 07:44 AM
Is anyone making sense of all this chatter..?
#14 hanra
  • 10,814 posts
Posted 04 May 2016 - 08:06 AM
No. Not really. But its entertaining.
#15 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 04 May 2016 - 08:18 AM
Poor bugger. 190°f is perfect. Only issue I see is his thermo is doing sweet FA bar making noise and drawing current.
#16 _mervx_
_mervx_
Posted 04 May 2016 - 05:35 PM
that about sounds like the original poster.thanks
#17 _ljxu1torana_
_ljxu1torana_
Posted 04 May 2016 - 09:21 PM
stop being a troll gary
#18 _mervx_
_mervx_
Posted 05 May 2016 - 09:37 PM
Stop being a Jason, thanks
#19 _ljxu1torana_
_ljxu1torana_
Posted 06 May 2016 - 01:29 AM
why are you acting like this for gary you look like a idiot.
