pintarra diff for lx diff conversion
6 replies to this topic
#1 _brenden_
_brenden_
Posted 29 May 2016 - 06:53 PM
Guys, need a helping hand. I have bought a pintarra diff and it is a 25 spline. the question is, will this fit into the lx if i change the mounts and how much work is it to replace the insides to a 28 spline lsd?  i have been told that its as simple as just replacing the inside axle's and centre is this true?
#2 dattoman
  • 16,471 posts
Posted 29 May 2016 - 06:59 PM
Replace the centre... you'll likely want to anyway
Get the axles in 28 spline to suit the pattern you need
If re-using the Nissan brakes you can buy undrilled rotors if need be from member "mantis" here
#3 _brenden_
_brenden_
Posted 29 May 2016 - 07:18 PM
thx dattoman, so the 28 spline axles will fit in the housing with no troubles? is there any thickness difference?
#4 gtrboyy
gtrboyy
  • 3,137 posts
Posted 29 May 2016 - 09:04 PM
Centre,brakes & axles change over to skyline
Blokes paying good money now for 4.11 pintara gears
#5 rodomo
  • 17,999 posts
Posted 29 May 2016 - 09:31 PM
Just use the banjo and spend the rest on driving lessons................................... :tomaatit:
#6 _brenden_
_brenden_
Posted 30 May 2016 - 06:19 PM
thx guys, in saying that what gear ratio should i go? its will be a fairly well worked 308 with a manulised trimatic. any suggestions?
#7 _mantis_
_mantis_
Posted 31 May 2016 - 06:17 AM
Skyline diff housings are the same as pintara just the guts are different  (interchangeable)
25 spline for 4 cyl 28 spline for 6cyl and are the same centre as commodore bw75
I have these in my 2 toranas  i run 3.08 lsd ratio but with manual gearbox
Edited by mantis, 31 May 2016 - 06:18 AM.
