Turbo 350 - tunnel mods required?
8 replies to this topic
#1 _NVR_ANUF_
_NVR_ANUF_
Posted 26 June 2016 - 10:20 AM
Thinking about going to an auto in my LX hatch. Has 308 and the good old aussie four speed in it at the moment. i know i'll need different cross member and modified tail shaft but just asking others if the turbo 350 fits in the trans tunnel with out needing to make mods to the tunnel itself?
#2 _ljshawn_
_ljshawn_
Posted 26 June 2016 - 10:40 AM
Should fit they fit in lj/lc without mods
#3 torana_nick
torana_nick
  • 759 posts
  • Name:Nick
  • Car:LH Torana Project
Posted 26 June 2016 - 10:46 AM
Stright fit no mods required.
#4 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 26 June 2016 - 12:08 PM
I put one in years ago and tunnel was fine but the shifter shaft on the T350 I used came out the left side of the box and I had to massage a bit of space into the tunnel right where it meets the flat floor st the front
Was not difficult
#5 ls2lxhatch
  • 5,329 posts
Posted 26 June 2016 - 12:27 PM
I had the same problem with the shifter shaft.
#6 yel327
  • 13,071 posts
Posted 26 June 2016 - 01:12 PM
You'll need a TH pattern block too.
#7 Redslur
Redslur
    Has been Torana owner
  • 3,531 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 26 June 2016 - 06:28 PM
No mods needed for mine.
#8 arrimar
arrimar
  • 3,121 posts
Posted 26 June 2016 - 06:43 PM
Order the speedo cable 6 inches longer.
#9 _NVR_ANUF_
_NVR_ANUF_
Posted 26 June 2016 - 07:30 PM
Thanks for the feedback guys appreciate it.
