202 dip stick dilemma
16 replies to this topic
#1 lctriples
lctriples
  • 405 posts
  • Name:paul
  • Car:LC 2 door, HR prem wagon
Posted 28 June 2016 - 09:36 PM
Just wondering how people have overcome the problem I just discovered when dropping a blue 3.3 commy motor into the old lc. blue sump has dipstick tube welded to passenger side of sump, whereas old red motor style is pushed into block, drivers side. Is it easy to knock welch plug out of blue block and slide red motor dipstick tube in, or do I need to cut and re-weld section from blue sump into red motor sump. Hopefully someone has experienced this hurdle in the past. The easiest solution would be to punch welch plug out, but not sure how simple that is. Thanks in advance - Paul.
  • Attached File  101.jpg   151.02K   4 downloads
  • Attached File  100.jpg   180.37K   4 downloads
#2 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 28 June 2016 - 09:49 PM
Knock out the welsh plug. It takes all of 2 seconds when you already have the sump off, then just use the red dipstick.
#3 _LS1 Taxi_
_LS1 Taxi_
Posted 28 June 2016 - 09:59 PM
Put a self tapping screw into the plug and pull it out with pliers. Can do this from the top with the sump on.
#4 _Bomber Watson_
+1
#5 lctriples
lctriples
  • 405 posts
  • Name:paul
Posted 28 June 2016 - 10:11 PM
Thanks guys, knew I could rely on forum members. I need to rip sump off tmrw to re-cut sump drain plug thread so will knock welch plug out then and let you know how it goes, thanks again for everyone help.
#6 lctriples
lctriples
  • 405 posts
  • Name:paul
Posted 29 June 2016 - 06:38 PM
All sorted, POP (piece of piss) in the end, Cheers paul
  • Attached File  102.jpg   107.17K   3 downloads
#7 _Bomber Watson_
Posted 29 June 2016 - 07:23 PM
Keep in mind for the majority of the early Commy lifespan they were still making WB commercials, so they needed both dip stick positions and I highly doubut an engine was designated to go to a certain place at a basic machining stage :D
#8 lctriples
lctriples
  • 405 posts
  • Name:paul
Posted 29 June 2016 - 07:49 PM
Thanks bomber, can you please clarify what you mean, thanks paul.
#9 _Bomber Watson_
Posted 29 June 2016 - 07:55 PM
Commodore had the pickup tube in the sump, WB had the pickup tube in the "regular" spot, they were making both models at once for a long time, and it would be very inconvenient to have to cast two seperate blocks or machine the same casting seperately for two different engines, So I can only assume they just cast and machined everything to suit both and in the assembly room where they were assigned engine numbers and the like either put a welch plug in the dipstick tube hole and a commy sump on it, or a dipstick tube in the dipstick tube hole and a WB sump on it.
#10 _Muzzy_
_Muzzy_
Posted 29 June 2016 - 08:29 PM
The WB dipstick is a different design to the red engine and red tube, the stick has a moulded plastic section that locks into the tube, somewhat different from the red that seals over the tube
#11 lctriples
lctriples
  • 405 posts
  • Name:paul
Posted 29 June 2016 - 08:42 PM
that makes sense, i thought I had done something wrong, cheers paul
#12 _Bomber Watson_
Posted 29 June 2016 - 09:08 PM
No shit sherlock, but It still fits into the block the same way yeah?
#13 rodomo
  • 17,998 posts
Posted 29 June 2016 - 09:22 PM
Commodore sumps have the pan at the front. WB at the rear (like Torana). I'd be checking the length of the dipstick/tube etc.
#14 Ice
  • 15,122 posts
Posted 29 June 2016 - 10:01 PM
Are the red and blue motor dipsticks the same length got a NOS one here no idea whats is off
#15 _Bomber Watson_
Posted 29 June 2016 - 10:04 PM
Send me a pick bruz.
#16 _Muzzy_
_Muzzy_
Posted 30 June 2016 - 08:48 AM
Sherlock here, yes, fit a blue or red , but fit as a pair
#17 _Bomber Watson_
Posted 30 June 2016 - 09:09 AM
Lol, I have seen a few commys running twin dipsticks, but your right don't mix ya tubes and sticks up.
